 1-15  …  996-1015  1016-1035  1036-1055  1056-1075  1076-1095  …  3116-3119
4446.1036
MagicaVoxel 0.0.2 is released, with:
• New Stroke Shapes: Quadratic Bezier (3-point), Oval (Cylinder), Star (Polygon)
• Icons: add icons to stroke panel and list.
• Stroke List: use SHIFT/CTRL to multi-select strokes in the stroke list. use right-click menu to rename layers and strokes.
https://ephtracy.github.io/index.html?page=magicacsg
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
4446.1037 In reply to 4446.1036
Excellent!
And don't forget to put the plugin Denoiser for a speedy Render! https://github.com/ephtracy/ephtracy.github.io/releases/tag/0.01
EDITED: 30 Jun 2021 by PILOU
4446.1038
Hi All
Made a funny little Vespa with MagicaCSG 0.0.1.
(in reminiscence of Mauro's Vespa tutorial :) )
I know Magica CSG 0.0.2 is out.
Already downloaded ;-)
EDITED: 30 Jun 2021 by SUBPATH2
Size: 351.4 KB, Downloaded: 89 times, Dimensions: 768x768px
Size: 350.4 KB, Downloaded: 80 times, Dimensions: 768x768px
4446.1039 In reply to 4446.1038
Onctuous lines! Bravo!
4446.1040
Thank you Pilou :)
And let me also thank you for all your good tipps
you have shared over the years in this post.
3D Coat Learnings becomes free!
https://3dcoat.com/2021announcement/
Numerous free file PBR also! (2500)
A special version only Texture + Render : named "Textura" will be low coast! Perfect for MOi! ;)
etc...
4446.1042 In reply to 4446.1038
Nice scooter model, Subpath!
─ Metin
4446.1043 In reply to 4446.1042
Thank you, Metin.
Was a lot of Fun to make it.
Love MagicaCSG a truly little Gem.
4446.1044
Hi all
Pilou, I hope you don't mind me introducing an free Online Tool here.
Stumbled across this free Online Tool, which may interest also
MOI Users, Graphic Designers because of Vectorgraphics.
(Results can be also saved as .SVG Vectorgraphic)
Its a kind of Halftone Generator.
You can use a Photo, choose between different Shapes and the space
between the Shapes and your Photo/Rendering would converted then
in a Halftone Picture. Which can also be saved as SVG.
Here the Link:
https://labs.adobe.com/experiments/hello-halftones/
Have fun being creative.
Size: 1.3 MB, Downloaded: 72 times, Dimensions: 768x995px
Size: 1.6 MB, Downloaded: 91 times, Dimensions: 768x995px
4446.1045 In reply to 4446.1044
Cool but it's a pity that they don't use colors of original image! :)
Here i reload the SVG inside the low cost Affinity Designer and exported as PDF for Import inside Moi3D!
It's of course 3 Moi's Objects! ;)
Maybe a day an SVG direct import inside moi ? :)
15 562 closed curves! (the entiere image)
EDITED: 2 Jul 2021 by PILOU
4446.1046 In reply to 4446.1045
Flow on a sphere of the all image : 15 seconds :)
4446.1047 In reply to 4446.1046
Wow, that flow on sphere gets me.
Cool Idea.
Do not miss the colors from the photo that much.
Because I am more interested in the patterns.
And inside the free Aerialod ;) (just Drag and Drop any image on the screen : magic! :)
https://ephtracy.github.io/index.html?page=aerialod (by EPHTracy MagicaVoxel, Magicacsg)
You can export as PLY of that so a 3D model ;)
4446.1049
Nice, Subpath and Pilou!
In my spare time I'm a big fan of experimenting with AI / ML for image / photo enhancement, particularly GANs (Generative Adversarial Networks).
Here's a Twitter thread where I posted some recent results:
https://twitter.com/metinse7en/status/1405465023015755776
─ Metin
4446.1050 In reply to 4446.1049
Wow, these photo enhancements impresses me.
Thanks, for your Link.
I am also always interested in such things and generative art.
Also Art and Design in general and of course admire the old Masters.
But i am not a Pro, only interested ;-)
4446.1051 In reply to 4446.1050
Every skill starts with interest! :)
─ Metin
Some infos :)
free ZPlugin for import / Export PLY pour ZBrush by Marcus Civis
Export quadrangles depuis ZBrush
5 500 faces dans MOiavec _importObj by Max Smirnov (_ImportObj 30 secondes)
EDITED: 5 Jul 2021 by PILOU
So cool the Modernist a free Shader by mode_vis for the free MagicaVoxel !
https://mode-vis.gumroad.com/?recommended_by=library&sort=page_layout#EhDwgL
MagicaVoxel : https://ephtracy.github.io/
4446.1054 In reply to 4446.1053
Thanks for the tip Pilou.
Wow there are a lot of incredible shaders for Magicavoxel
4446.1055
Hi all
Here is another tool worth mentioning.
"Sceelix" (Mac/PC/LInux) has been open source
for some time. Was sold on Steam before that.
"Scellix" is a standalone procedural generation
software in the vein of a node modeler. But don't
expect too much, it is still in an early stage.
The File contains a few examples.
Homepage Link:
https://sceelix.com/docs/Introduction/AboutSceelix
and a vid:
https://www.youtube.com/watch?v=aSgJPN6qK5I
Show messages:  1-15  …  976-995  996-1015  1016-1035  1036-1055  1056-1075  1076-1095  1096-1115  …  3116-3119
