 1  …  982-1001  1002-1021  1022-1041  1042-1061  1062-1081  …  3102-3119
Always amazed by that! Excellent! Bravo for the try!
here with a Moi object! :)
EDITED: 26 Jun 2021 by PILOU
4446.1023 In reply to 4446.1021
I' sorry if I my sound a little bit rude...but, for me personally, computer generated graphic is absolutely NOT art, at all.
Even a monkey can press a button and let things happen (with all due respect to monkeys).
Art is just something else.
P.s.
For the sake of completeness, I mean "automatic computer generated art", that is every kind of digital contents not directly created by artists but merely created by mathematical algorithms written by developers and scientists.
That kind of content, for me, is absolutely NOT art.
Seems the ED's image is entierely controled by him...place, form, nature of type of filling...
he don't say its art, he said that is photo as background for some objects! ;)
4446.1026
Well, this Monkey example is used often. But I don't think a monkey could do that,
in the end people are needed to make these pictures and even more
important to evaluate them what no monkey and no software could do.
Besides, I find it difficult to say what is art and what is not nowadays.
Why not just stay open for new possibilities.
I think something like this can be used to visualize ideas? Or as a
template for a picture that is painted by yourself.
4446.1027 In reply to 4446.1026
Who claimed it was art?
Next version of the free MagicaCSG will have Bezier Quadric and other funny things! :)
4446.1029 In reply to 4446.1028
Yeah, looking forward to those splines. They will only have three curve manipulation points though. Hopefully that will be extended in a next version.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
4446.1030
Thank you for your tip, Pilou.
Find MagicaCSG already a nice little gem.
But miss the grouping of strokes.
Here is my first attempt.
Size: 254.6 KB, Downloaded: 126 times, Dimensions: 768x768px
4446.1031 In reply to 4446.1030
You can group strokes with layers in MagicaCSG, and the order of the strokes list is also important for different results (which strokes are affected by other strokes).
─ Metin
4446.1032 In reply to 4446.1031
Thank you for the Info, Metin.
By the way I like the great examples you
made with MagicaCSG. Very well done.
In the meantime I found the "Select All" button.
With this button you can select all strokes of a layer.
I should have just opened my eyes ;-)
And this way I can now put parts of an object on a
separate layer and select them if I need that.
4446.1033 In reply to 4446.1032
Many thanks for your compliment, much appreciated!
The next MagicaCSG version will introduce a number of UI / UX improvements. I hope it will be released soon.
Regards from the Netherlands,
─ Metin
Demo of the next version of MagicaCSG :)
https://twitter.com/i/status/1409302243577315333
4446.1035 In reply to 4446.1034
Thanks Pilou!
What a wonderful software is MagicaVoxel!
4446.1036
MagicaVoxel 0.0.2 is released, with:
• New Stroke Shapes: Quadratic Bezier (3-point), Oval (Cylinder), Star (Polygon)
• Icons: add icons to stroke panel and list.
• Stroke List: use SHIFT/CTRL to multi-select strokes in the stroke list. use right-click menu to rename layers and strokes.
https://ephtracy.github.io/index.html?page=magicacsg
─ Metin
4446.1037 In reply to 4446.1036
Excellent!
And don't forget to put the plugin Denoiser for a speedy Render! https://github.com/ephtracy/ephtracy.github.io/releases/tag/0.01
EDITED: 30 Jun 2021 by PILOU
4446.1038
Hi All
Made a funny little Vespa with MagicaCSG 0.0.1.
(in reminiscence of Mauro's Vespa tutorial :) )
I know Magica CSG 0.0.2 is out.
Already downloaded ;-)
EDITED: 30 Jun 2021 by SUBPATH2
Size: 351.4 KB, Downloaded: 89 times, Dimensions: 768x768px
Size: 350.4 KB, Downloaded: 80 times, Dimensions: 768x768px
4446.1039 In reply to 4446.1038
Onctuous lines! Bravo!
4446.1040
Thank you Pilou :)
And let me also thank you for all your good tipps
you have shared over the years in this post.
3D Coat Learnings becomes free!
https://3dcoat.com/2021announcement/
Numerous free file PBR also! (2500)
A special version only Texture + Render : named "Textura" will be low coast! Perfect for MOi! ;)
etc...
Show messages:  1  …  962-981  982-1001  1002-1021  1022-1041  1042-1061  1062-1081  1082-1101  …  3102-3119
