i know this is probably more of a mathematical problem than not, but it would be awesome if you there was a way to have "on-curve" anchored snap points such that any other curve that attaches to it must pass through that point no matter what adjustments are made made afterwards (kinda like linking points on curves).
Usually if I draw a curve through points and leave it alone it works wonderfully, but any time control points are adjusted on that curve there is a likely chance that it no longer touches upon the original set of points and/or snaps used to create it.
Obviously this may affect surrounding control points to account for the "must pass-through point" requirement, but this would ensure they always touch or intersect at the desired location.
Do you think there's is such a possibility? or is there a way to do this currently?
Luis
