V3 beta Aug-24-2011 available now
 1-10  11-30  31-50  51-70  71-90  91-101
4438.51 In reply to 4438.50
of course I prefer by far a command like Flow then a thumbnail preview. I just give my suggestions as they come.
Felix
4438.52
Excuse me if this has already been answered. I did some searching but couldn't find anything. Will there be a 64bit version of MOI V3? I'm running out of memory quite often when trying to mesh big models with V2.
4438.53 In reply to 4438.52
Hi Sun, currently I don't have any plans for a 64-bit version of v3. It would take quite a lot of effort to make that happen, it involves not just MoI's core code but also getting 64-bit versions of various support libraries that MoI uses as well so altogether that's a highly time consuming project to undertake.
If you have a pretty complex model your best bet is to select some portions of it and use the File > Export command which only writes out just the selected objects instead of writing everything. Writing things out in a couple of chunks like that instead of all at once should help to avoid running out of memory.
4438.54
In the numeric input field, the white space between the 1 2 3 button and the 0 , - button is different.
Is this intended ?
Size: 17.9 KB, Downloaded: 167 times, Dimensions: 250x288px
4438.55 In reply to 4438.54
Hi Paolo,
> Is this intended ?
That's not intended - it's a bug that happens if your locale uses the comma character as the decimal separator, thanks for reporting it!
I've got it fixed up now for the next beta and you can also apply the fix by copying the updated attached files over top of the previous versions in the \ui subfolder underneath MoI's main installation folder.
4438.56 In reply to 4438.55
Problem fixed
4438.57
Is V3 supposed to give error feedback when a command fails, for instance I tried to draw an arc tangent between two curves and received the dummy spit attached, I did realise that one of my curves wasn't planar because of it though, if I interpreted it right that is :S , if this is intentional could we have a simpler error like 'Curves non planar' that would be cool.
4438.58 In reply to 4438.57
Hi Danny, a script error like that is meant to give debugging information to the person developing the script, it's a bug when you see those in a finished script.
I'll fix that up for the next beta release, thanks for reporting it.
At some point I want to figure out a good place where things could give feedback on error situations like things being not all in the same plane like this case. I have not yet figured out a good place to stick error messages like that though, I kind of need some area of the UI where several lines of text messages can be streamed out.
4438.59 In reply to 4438.47
Yep. Wasn't sure if you already got to it.
4438.60
Just wondering if it's possible to get a another modifier key combo for selection to do an inverse select?
4438.61 In reply to 4438.60
Hi Danny,
Do you mean for selection using the scene browser, clicking on the selection indicator dot area?
How about Ctrl+A (for select all), and then just do a regular left click on the dot with no modifier key to deselect it, does that produce the result you're looking for?
I guess I could make right-click on the selection dot work like it does on the eye where if the item is already the only thing selected (already isolated) it would select everything.
If it was set up like that then you would do a right-click on it either once (if it was already the isolated selection) or twice (first click isolates it if it wasn't already isolated), and then a left click to deselect it.
Michael, could you please recommend an htm editor wysiwyg? (For webkit/MoI3)
It seems like the new htm do not display in Internet explorer window, in Notepad++, or pagebreeze. ?
Also a javascript editor?
Also where to get javascript documentation, re webkit?
Thankyou
I had to copy lineweb scripts manually. (?)
EDITED: 29 Aug 2011 by BEMFARMER
4438.63 In reply to 4438.62
Hi bemfarmer,
> (For webkit/MoI3)
You can't really use a standard html editor if you want to use the same stuff that MoI uses itself, because several of the MoI UI controls are built with custom elements that are not in regular html.
Your best bet is just a text editor like notepad++ or notepad2.
You could use a standard html editor though if you wanted to make your own kind of custom UI that didn't use the same controls that the regular MoI UI is made up of, and also other pieces of infrastructure like the templating mechanism.
That's normal that they would not display in Internet explorer since IE does not implement the various custom tags that MoI makes available.
But they're just text files so you should be able to open them in Notepad++, are you having some problem just viewing the files as text in Notepad++ ?
This is also done best with a text editor same as for the HTML files.
There's a variety of stuff online, here is a good place to start:
http://www.w3schools.com/
Do you mean you used the script copier utility and it did not copy that particular one? The script copier utility is available here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4438.32
4438.64 In reply to 4438.63
Thank you Michael. I'll keep using Notepad++.
I'm working on another curve script, for fun and learning.
4438.65 In reply to 4438.61
Yes, and any of your suggestions would work, if you didn't want to add the right click option the Ctrl+A and deselecting the required part will work, I didn't think of that :) Thanks.
4438.66 In reply to 4438.65
Hi Danny, also I guess just a shortcut for doing a regular invert would do the trick as well.
It's pretty handy to have that set up on the I key. To do that, go to Options > Shortcut keys and add in a new one.
For the key put in I and for the command part put in this:
script:moi.geometryDatabase.invertSelection();
After that you can invert the selection anytime by pushing the I key.
Then to use it with the scene browser, do one right-click on the selection dot for the item - that will make that item the isolated selection deselecting any other things. Then push I after that and you should get your inverted selection that you want.
The only thing to be aware of is that if you have sub-objects selected (faces or edges), it will invert the selection of the same kind of sub-objects within that same parent and not alter other things.
4438.67 In reply to 4438.65
Hi Danny, by the way have you been using the selection dot and the filters some?
How do those seem to be working aside from that filter bug you reported and having the name label running under the dot (both of which I will be tuning up).
Other than those things does it seem like that is going to work?
4438.68 In reply to 4438.67
Yeah, so far so good, I need a little more time to assess it fully, I'll be on it for a few hours when I get home tonight, I have a little project that I have to do, so be sure I'll have some feedback for you once I get more hours up using it.
4438.69
I might have missed it somewhere in the forum or refresh my memory, why did you go for the little square option for selection in the browser, have you got something planned for the rest of the area where the name sits, the reason I ask is because it felt more comfortable selecting the whole name of the object or type etc. as a matter of fact I still try to.
4438.70 In reply to 4438.69
Hi Danny,
Well, actually it was partly from a discussion with you back a while ago asking to have a selection indicator. It seems to make sense to make the indicator also be the place to trigger the selection action as well - that makes it resemble how clicking on the eye works for showing and also toggling visibility. Then it also frees up clicking on the name for something else.
Yeah I want to make a menu pop up with some additional stuff on it. Like for example things like "Delete" for styles, or "Assign selection to this name" for named objects can then go on that menu.
That's probably due to the habit of how V2 was set up. Hopefully it won't take too much longer to adapt to the new method. Let me know if it still doesn't feel very good after a few more sessions of using it.
Show messages:  1-10  11-30  31-50  51-70  71-90  91-101
