Hi Steve,
> Just copied the scripts. The Pipe command fails.
Looks like an actual error in the script that the old script engine happened to silently ignore for some reason.
Please try the attached updated version - this new version should work in either v2 or v3 now.
In addition to the UI for v3 being on a new system, the script processing also is using a new system as well and there may be a few kinks related to that, like in this case with a slight difference in error handling making a difference to how the script was executed. It should only require minor tweaks to fix up these kinds of issues as well.
