V3 beta Aug-24-2011 available now
 1-20  21-40  41-60  61-80  …  101
4438.21 In reply to 4438.10
Hi Yenmonger,
> Bug report: selecting a style name no longer
> selects all objects of that style.
Instead of clicking on the name, there is a new selection indicator dot on the far right column to the right of the name:
That shows you the selection state of the item with a full yellow dot if all objects of that slot are selected, and a half dot if some are selected and some are not.
Click on that dot to toggle selection on or off similar to how clicking on the eye toggles visiblity on or off.
When you click on the dot it will only select objects that are not hidden - use shift+click to select all objects of that slot regardless of current visibility state (any hidden objects will become shown if you do that).
Right click on the dot to do an "isolated selection" - it will select the item and deselect all other things.
You can also use Ctrl+click on that same spot to activate a selection filter - when a filter is active only objects that belong to that slot will be targeted for selection actions, so for instance if you want to select all red curves, you can tag Style = Red with a filter, and then go to the Types section of the scene browser and click on the selection indicator for curves and it will only target curves that have style = red. You can push Escape to clear any active filters when you are done using them.
4438.22 In reply to 4438.11
Hi Luis,
> Just wondering...what will be the pricing for upgrading
> from V1 to V3??
I'm not really sure if there will be an upgrade from v1 to v3 - there might only be one from v2 to v3...
> Can I try V3 Beta with a V1 license??
Sorry, not currently - right now I kind of assume that if you're interested in having the latest stuff that you would have already updated to v2 a while ago...
4438.23 In reply to 4438.12
Hi OSTexo,
> On a side note it seems my models are loading faster, or
> is it just my brain tricking me? As usual the beta is very
> stable, great work.
It could be possible - one of the things that is updated is the OpenNURBS library for loading 3DM files.
Particularly if you're loading Rhino v4 or v5 files I think the new library may be able to find each section it is looking for in its proper place instead of trying to scan through the file to find them, or something like that.
4438.24 In reply to 4438.14
Hi OSTexo,
> I am having a view reset problem, I load a file and when
> I hit the view reset button it zooms out so far that the
> model becomes a dot on the screen.
Is it possible for you to send me the file through e-mail (moi@moi3d.com) so I could test with it?
4438.25 In reply to 4438.12
Hi OSTexo,
> Perhaps a short tut would be good.
Check out here for a real basic one with an example file:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4363.191
(for curve-to-curve flow)
4438.26 In reply to 4438.20
Thanks Michael G. Keep up the fantastic work!
Michael T.
4438.27
Thanks for the response, and it might be wise to use the idea of putting some visible indicator next to the name. I would have had NO idea to click so far to the right, and I've been using your program for years.
4438.28 In reply to 4438.27
Hi Yenmonger,
I can probably make something additional show up when you have your mouse over the line to make it more apparent that the right side is a clickable area.
4438.29 In reply to 4438.20
Does the new UI enhancement mean you going to suport other OS then Microsoft Windows in the future?
4438.30 In reply to 4438.29
Hi Robert,
Well, it's at least one step towards that.
It's potentially enough of a step to make it happen soon if things work well enough running under the WINE compatibility library.
If using WINE does not work out then there are still some remaining steps that would be necessary to have a full port done. If that's the case then those additional steps would probably happen sometime after v3.
At the moment it's still an unknown as far as how that will work out.
4438.31
Am hoping I'll have some time to play with V3 over the weekend - fun!
Script copier for this release is attached here.
This is a utility program that will copy any custom plug-in commands that you had installed in MoI v2 under the \commands sub-folder over into this new beta's \commands sub-folder.
For the most part scripts for MoI v1 and v2 should just run directly in MoI v3. There will probably be a couple of them that will need some minor tune-ups if their UI happened to use some functions that are specific to Internet Explorer.
Let me know if you run into any that need tuning up - I have not yet tested every single plug-in with v3 myself.
4438.33
Hi
Looks great wit the new V3 beta. Moi is an amazing program, and i am using it very frequently.
Unfortunately it looks like i am not capable of downloading V3 beta since i have V2 upgrade licence, and i would very much like to test that. How can i proceed?
4438.34 In reply to 4438.33
Just copy the serial number of your v2 in the Download box
http://moi3d.com/beta.htm
4438.35 In reply to 4438.34
Now it worked... thanks
4438.36
Selection filter is great, this will help me manage my scenes much better.
4438.37
Just a quick question. Is this the intended scope of the new release, or can we expect to see quite a few more features introduced?
4438.38 In reply to 4438.33
Hi hep - yeah it should work to use a V2 upgrade license for downloading the beta. Not sure what happened on your first attempt but I'm glad you've got it now.
4438.39 In reply to 4438.37
Hi Andy,
This is just the beginning - the beta period will last for a while, maybe something like 8 more months or a year and there will be a lot more new stuff coming.
You can add your top 5 requested features to this thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.1
4438.40
Just copied the scripts. The Pipe command fails.
Show messages:  1-20  21-40  41-60  61-80  81-100  101
