How would you model a pelton wheel?
All  1-3  4-8
4427.4
Hi Sharky,
You could try "adding" and "subtracting" simple shapes together to get your shape.
The process could be done with the more accurate shape that Michael has made above, where the middle crease remains level.
But this is a quick one example...
1) Draw the outside shape of the cup.
2) Use Revolve to create an egg shape.
3) Draw one straight line in a side view and do a Boolean Trim to cut the egg in half.
4) Delete the top egg half and copy the shape to one side.
5) Boolean Union the two halves together. Delete the flat side objects, as in mine it looked like one overlapped the other.
6) Select the outer curves that make up the flat side, Planar them to get a nice flat area and Join that to the double egg half shape.
7) Do the same thing to make a smaller double egg, Union them together.
8) Boolean Trim the smaller double egg from your larger part.
9) Draw that funny cut-out shape, copy it and Boolean Trim them from the new hollowed out shape.
10) Add the rest to make the tool shape. The the rest will be a series of Copy Rotations and etc.
Hoped this helped also.
Mike
4427.5 In reply to 4427.4
Is this an art project, to make something that looks like a pelton, or
an engineering project to make the curves match the efficient conversion of energy?
Anyway, an interesting project!
4427.6 In reply to 4427.5
On 3D content central there is a pelton wheel 3D, And a paddle
There are several formats, solidworks, STEP, STL, etc.
Here is step version of the paddle, imported to MoI.
Looks a bit klunky, not due to MoI. (The Solidworks and STEP versions look klunky also, in other viewers.)
EDITED: 2 Apr 2015 by BEMFARMER
4427.7 In reply to 4427.6
The Pelton Wheel by another person looks a lot better:
Size: 45.2 KB, Downloaded: 156 times, Dimensions: 494x411px
4427.8
Wow what a helpful community! Thanks for all the hints! I am going to give it another go today and I'll post what I come up with.
Show messages: All  1-3  4-8
