Duplicate Vertices on OBJ Export
All  1-3  4-9
4424.4 In reply to 4424.1
Hi Skwerm, also just some more info - unless you're doing some kind of special effect like a toon render that is specifically looking for open edges in the mesh there should not be any difference between rendering a welded mesh or an unwelded mesh.
That's because the shading of the mesh is supposed to be controlled by the vertex normals data that is also present in the OBJ file.
If you get a different looking render between an unwelded versus a welded mesh, then that means that your program is ignoring the vertex normals that were supplied in the file and instead trying to calculate brand new ones from scratch by averaging together faces that share points in common.
Blender has a problem with doing precisely that in the latest 2.5x versions - currently their OBJ import script just ignores all the vertex normal data in the OBJ file (those are the lines that start with 'vn') and try to calculate new ones just from the polygonal information. That's not good for CAD data because the normals that have been discarded are ones that have come from the original NURBS surface data and it isn't really possible to get the same exact ones back just by averaging the polygon data since the polygons are only an approximation of that original smooth NURBS surface.
Please see this previous post here for a lengthy description of how vertex normals in the OBJ file are supposed to be used by a rendering program:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4272.3
Basically, as long as Blender just throws away the vertex normals in the OBJ file instead of reading them in and using them, it will always have a problem with CAD data. To my knowledge, Blender is the only rendering program that has this particular problem - all the other rendering programs that I am aware of do read in the vertex normals from an OBJ file and use it to shade the rendered polygon instead of just ignoring them and recalculating them from the polygon face normals.
4424.5 In reply to 4424.1
Hi Skwerm, also see this thread on the Blender artists forum that talks about the problem with the Blender importer ignoring the vertex normal data:
http://blenderartists.org/forum/showthread.php?182195-OBJ-import-normals
4424.6 In reply to 4424.2
<< I'm curious about why MoI export to OBJ (and perhaps other formats, I haven't checked) includes duplicate vertices. I was reading another thread here about Octane having problems rendering MoI output and the subject came up about duplicate vertices.>>
I don't think that the duplicate vertices in that case were due to a seam from MoI (since the duplicates are all over the place and not just on a seam). It was just due to a very sloppy mesh. That is why I doubted that the mesh came from MoI, since I have never seen MoI create random duplicate vertices all around the mesh. If you want to take a look at that mesh yourself, you can find it here: http://refractivesoftware.com/forum/download/file.php?id=10501
<< The question then becomes "why isnt Octane or Blender reading the true vertex normals from the obj file and screwing up the shading??
This question is for Blender or Octane though, not MoI.>>
Octane doesn't have a problem reading in normals from MoI.
Blender ignores normal information and calculates its own (which ends up messing up renders from MoI).
4424.7 In reply to 4424.6
Sorry YHWH,
I didnt mean to insinuate anything about Octane. I was just responding to the OP and how it's not a question about MoI....
4424.8
Thanks everyone for all the help!
I'd always just turned off "Weld Vertices" because of a thread I read back when I started with MoI that said Blender really needed it turned off in order to help with the vertex normals. I hadn't "put two and two together," so to speak, and realized that this was where my current question was originating from.
I'll see what I can do about getting the developer for the OBJ import for Blender to address this problem. If nothing else, I'd like an answer as to why they're being ignored. My guess is that it's just easier to recalc the vertex normals rather than deal with the imported ones.
Cheers!
4424.9 In reply to 4424.8
Hi Skwerm,
> the vertex normals.
It wasn't really Blender itself that needed it turned off - it was a particular import script that Anthony wrote to import moi-generated LWO files into Blender. That particular script needed welding to be off just because it was easier for him to write that one script that way.
Unfortunately Blender has several other problems with vertex normals aside from ignoring them on OBJ import - when you go to edit mode any existing vertex normals are discarded and recreated from the polygon data, and also when you go to render it also discards them.
Here are a couple of previous discussion threads about it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4256.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=3583.1
There doesn't seem to be very much interest by the Blender devs on fixing up these problems - for example a while back someone opened a bug that any imported vertex normals are discarded if you just go to edit mode and back out again without actually doing anything, and the bug was rejected:
http://projects.blender.org/tracker/?group_id=9&atid=498&func=detail&aid=26405
So for now anyway with all these vertex normal problems Blender is not really very well suited for rendering CAD data compared to other rendering programs.
Sure I guess that's easier but it's also incorrect when the vertex normals in the file are holding information that you can't easily recreate. That's what will happen when the OBJ file was generated from some other original data source than polygons. Like in the case of MoI the normals that are stored in the OBJ file come from the NURBS surface data, so they represent the ideal normal for that point. Since Blender doesn't have access to the original NURBS surface there isn't any way for them to regenerate that exact same data just by trying to average normals from polygon faces.
Show messages: All  1-3  4-9
