Project
4422.1
Could we get a 'Delete input curve' checkbox for Construct>Curve>Project, when constructing with a lot of curves I sometimes find that I've been inaccurate and some of the curves aren't on the same plane, so I create a Plane and slap the curves against that using 'Project' and because the two sets of curves end up very, very close and most zero/zero it's hard pick the new set from the old, I know I can change the colour before projecting, but then it ends up a back and forth thing.
4422.2 In reply to 4422.1
Hi Danny,
Yeah that should be feasible - I 've added it to my todo list for v3 tuneup stuff, I'll probably be working on some of that list for the 2nd v3 beta.
For now the easiest way to tune up curves like that is probably to go to a side elevation view and use the edit frame - when you grab a corner of the edit frame and move it downwards you'll get a "flat" snap. If you don't get a flat snap it means it was already flat.
Anyway when you use the edit frame you won't have 2 sets of curves to deal with, it edits the curves in place.
4422.3 In reply to 4422.2
Ah yes! cool suggestion Michael, I'll give that a try.
