Hi Chyman,
> Not sure what is going wrong this time... I am using
> Wine version 1.3.32 too... perhaps the Intel GMA X3100
> hardware is a problem..
Hmm, I hope that doesn't mean that MoI won't work on the GMA X3100 as well - the mac mini I'm testing with has a Radeon HD 6630M which seems to be working well.
Could you try the attached sample program and see if that one has the same problem too?
> Your description of Wineskin sounds a bit like Winebottler you
> mentioned previously, that bundling is indeed of advantage for
> creating a defined environment, I will have a closer look at it.
Yeah, it's the same kind of thing as Winebottler, but it seems like Winebottler has not had much activity around it for the past year or so, while Wineskin is quite active with the developer supporting it with a forum and updating it frequently.
