Moi and Ubuntu
 1-11  12-31  32-51  52-71  72-91  92-105
4409.32 In reply to 4409.31
Hi Phr0stByte,
> Do you need to install the windows version of the video driver into wine?
No Wine itself uses OpenGL and will make use of whatever OpenGL driver is installed already, you don't need to (and can't really) install drivers within Wine itself.
4409.33
OK - I tried on my desktop and I get an inkling that things might work under the perfect storm of circumstances. Here is what I get:
phr0stbyte@Phr0styBox:~/.wine/drive_c/Program Files/MoI 3.0 beta Aug-24-2011$ wine MoI.exe
fixme:process:GetSystemDEPPolicy stub
fixme:process:SetProcessDEPPolicy (0): stub
Error: API mismatch: the NVIDIA kernel module has version 280.13,
but this NVIDIA driver component has version 275.21. Please make
sure that the kernel module and all NVIDIA driver components
have the same version.
err:winediag:X11DRV_WineGL_InitOpenglInfo Direct rendering is disabled, most likely your OpenGL drivers haven't been installed correctly
fixme:dbghelp:elf_search_auxv can't find symbol in module
I think that NVIDIA driver component has version 275.21 is an old version. I am not sure how to fix this though, as I don't want to break things so that Octane doesn't work (it does now, and wonderfully so). NVIDIA drivers are hard enough just to keep working under linux.
-Phr0stbyte models are for sale here: http://www.turbosquid.com/Search/Artists/Phr0stByte?referral=Phr0stByte
4409.34 In reply to 4409.33
Hi Phr0stByte - what actually happens on your desktop machine though, is there still a core dump when you run it there, or does the rest of MoI show up except for the 3D viewport display?
What happens on your desktop system if you edit the MainWindowLayout.xml file as described previously here: http://moi3d.com/forum/index.php?webtag=MOI&msg=4409.25 does that make the rest of the UI come up without the viewports or still not?
4409.35
Actually, never mind! I just got the nVidia mismatch sorted out and MoI v3 beta is working! Hurry up and start selling it! :)
4409.36 In reply to 4409.35
Hi Phr0stByte, that's great news that you've got it up and running now!
So it's still a no-go on your laptop, is that correct? But it is running ok using Wine on your desktop machine now?
4409.37
That is correct. I will play a little bit more on the laptop, but I mostly just use my desktop, as that is where the beefy h/w is. But the laptop would definately be a bonus.
[EDIT] It is now working on the laptop too! Woohoo!!!
EDITED: 2 Sep 2011 by PHR0STBYTE
4409.38 In reply to 4409.37
Hi Phr0stByte, was there any particular change that you did on the laptop to get it working, was it also a video driver tuneup there as well?
4409.39
Yep - I could not say exactly what fixed it. I just kept monkying with the driver until it worked. I was actually stuck without any display at all in one point and only had tty. Luckily, I got it all back plus the nice little bonus of having MoI working :)
4409.40
A little update - I tried to get the MoI v3 beta running on my Macbook Pro too using wine, but I can't get it to run. Any Mac users out there have any input?
4409.41
Russian:
Привет всем!
Все сделал так, как вы здесь написали. Но программа запускается в таком виде и выдает следующее сообщение (nVidia GeForce 9600GT, Kubuntu 11.04, Wine 1.3.15):
English (Goggle):
Hi everyone!
I've done everything as you wrote here. But the program is run in such a form and show the following (nVidia GeForce 9600GT, Kubuntu 11.04, Wine 1.3.15):
*** wine MoI.exe
fixme:toolhelp:CreateToolhelp32Snapshot Unimplemented: heap list snapshot
fixme:mountmgr:harddisk_ioctl unsupported ioctl 74080
fixme:mountmgr:harddisk_ioctl unsupported ioctl 2d1400
fixme:system:SetProcessDPIAware stub!
fixme:win:EnumDisplayDevicesW ((null),0,0xe4f804,0x00000000), stub!
fixme:heap:HeapSetInformation 0x110000 0 0xe4f330 4
fixme:advapi:RegisterTraceGuidsW (0x638962c3, 0x63ab1058, {ffdb9886-80f3-4540-aa8b-b85192217ddf}, 1, 0xe4ef78, (null), (null), 0x63ab1058,)
fixme:advapi:RegisterTraceGuidsW (0x638964fa, 0x63aae200, {0cfe0455-93ba-440d-a3fe-553973d0b723}, 1, 0xe4ef5c, (null), (null), 0x63aae208,)
fixme:advapi:RegisterTraceGuidsW (0x638964fa, 0x63aae220, {797fabac-7b58-4796-b924-d51178a59ce4}, 1, 0xe4ef5c, (null), (null), 0x63aae228,)
fixme:advapi:RegisterTraceGuidsW (0x638962c3, 0x63ab1088, {9e3b3947-ca5d-4614-91a2-7b624e0e7244}, 1, 0xe4ef78, (null), (null), 0x63ab1088,)
fixme:ntdll:NtQueryInformationToken QueryInformationToken( ..., TokenElevationType, ...) semi-stub
fixme:msimtf:DllGetClassObject ({50d5107a-d278-4871-8989-f4ceaaf59cfc} {00000001-0000-0000-c000-000000000046} 0xe4f548)
err:ole:apartment_getclassobject DllGetClassObject returned error 0x80040111
err:ole:CoGetClassObject no class object {50d5107a-d278-4871-8989-f4ceaaf59cfc} could be created for context 0x401
err:ole:CoGetClassObject class {82c5ab54-c92c-4d52-aac5-27e25e22604c} not registered
err:ole:create_server class {82c5ab54-c92c-4d52-aac5-27e25e22604c} not registered
fixme:ole:CoGetClassObject CLSCTX_REMOTE_SERVER not supported
err:ole:CoGetClassObject no class object {82c5ab54-c92c-4d52-aac5-27e25e22604c} could be created for context 0x17
fixme:advapi:RegisterTraceGuidsA (0x633fa1fa, 0x634235c0, {0cfe0455-93ba-440d-a3fe-553973d0b723}, 1, 0xe4ee78, (null), (null), 0x634235c8,)
fixme:advapi:RegisterTraceGuidsA (0x633fa1fa, 0x634235e0, {797fabac-7b58-4796-b924-d51178a59ce4}, 1, 0xe4ee78, (null), (null), 0x634235e8,)
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4f3e0, (null), (null), 0x63420f60,)
err:ole:CoGetClassObject class {6c736db1-bd94-11d0-8a23-00aa00b58e10} not registered
err:ole:CoGetClassObject no class object {6c736db1-bd94-11d0-8a23-00aa00b58e10} could be created for context 0x1
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4f538, (null), (null), 0x63420f60,)
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4f3a8, (null), (null), 0x63420f60,)
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4f3b8, (null), (null), 0x63420f60,)
fixme:wininet:FindFirstUrlCacheContainerW (0xe473a8, 0xe473b4, 0xe473b0, 0x00000000) stub
fixme:wininet:CreateUrlCacheContainerW (0x1a43ac84, 0x1a43ff50, 0x00e47188, 0x00000000, 0x00000000, 0x00000009, 0x00000000, 0x00000000) stub
fixme:nls:WideCharToMultiByte UTF-7 not supported
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4ef08, (null), (null), 0x63420f60,)
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4eef8, (null), (null), 0x63420f60,)
fixme:dwmapi:DwmIsCompositionEnabled 0xe4e6bc
fixme:advapi:RegisterTraceGuidsA (0x6340dbc9, 0x63420f20, {4160f1e0-5fc8-41ac-bfec-b60134f2d570}, 1, 0xe4eb10, (null), (null), 0x63420f60,)
fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETAUTOHIDEBAR, hwnd=(nil), edge=0): stub
fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETAUTOHIDEBAR, hwnd=(nil), edge=1): stub
fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETAUTOHIDEBAR, hwnd=(nil), edge=2): stub
fixme:appbar:handle_appbarmessage SHAppBarMessage(ABM_GETAUTOHIDEBAR, hwnd=(nil), edge=3): stub
fixme:wininet:FindFirstUrlCacheContainerW (0xe48f04, 0xe48f10, 0xe48f0c, 0x00000000) stub
fixme:wininet:CreateUrlCacheContainerW (0x1a43ac84, 0x1a43ff50, 0x00e48ce4, 0x00000000, 0x00000000, 0x00000009, 0x00000000, 0x00000000) stub
fixme:advapi:RegisterTraceGuidsW (0x132313b8, 0x133f2830, {b2a40f1f-a05a-4dfd-886a-4c4f18c4334c}, 1, 0xe49e30, (null), (null), 0x133f2830,)
fixme:advapi:RegisterTraceGuidsW (0x132313b8, 0x133f2860, {ffdb9886-80f3-4540-aa8b-b85192217ddf}, 1, 0xe49e30, (null), (null), 0x133f2860,)
fixme:advapi:RegisterTraceGuidsW (0x132313b8, 0x133f2890, {5c8bb950-959e-4309-8908-67961a1205d5}, 1, 0xe49e30, (null), (null), 0x133f2890,)
fixme:advapi:RegisterTraceGuidsW (0x13231481, 0x133f12c8, {3e1fd72a-c323-4574-9917-5ce9c936f78c}, 1, 0xe49e10, (null), (null), 0x133f12d0,)
fixme:advapi:RegisterTraceGuidsW (0x13231481, 0x133f12e8, {afff9c82-5be3-4205-9b3e-49e014c09a63}, 1, 0xe49e10, (null), (null), 0x133f12f0,)
fixme:wininet:GetUrlCacheEntryInfoExW Undocumented flag(s): 100
fixme:win:EnumDisplayDevicesW ((null),0,0xe4a770,0x00000000), stub!
fixme:d3d:swapchain_init Add OpenGL context recreation support to context_validate_onscreen_formats
fixme:mlang:fnIMLangFontLink_ResetFontMapping
fixme:advapi:UnregisterTraceGuids 0: stub
4409.42 In reply to 4409.41
Hi Alex,
> Hi everyone!
It looks like the Direct3D to OpenGL translation layer of WINE is not working properly for you there.
That could possibly be a bug in WINE or it seems that often the video drivers on Linux can tend to be pretty buggy as well.
You might try a previous version of WINE or try a different version of your video driver.
Unfortunately getting a reliable video driver working on Linux seems to be a big problem.
4409.43
Wow! The program works on my Kubuntu!
I deleted all the Nvidia drivers and installed new Nvidia manually from the site. And the program started!
Thank you all for your advice and all the luck!
4409.44
Hello:
Finally, I got MoI under wine too!
Unafortunately, it doesn't run fine. There are a delay between I click on the mosue and I see the point on the screen.
It's too much delay for considering this method like a real option to get MoI in Linux. :-(
I have:
Linux Mint DE 64 bits
Wine-1.3.29
MoI v3
Seems that hardware acceleration runs ok.
My graphic card NVDIA 6600 GT
Then, ¿It's normal this slow behavior?
Could anyone that uses MoI under Linux give any trick, or information about his machines,SO,wine version, etc...
Thank you
4409.45 In reply to 4409.44
Hi David, if everything is working ok then I wouldn't think it should be normal to see a delay like that.
It seems that by far the most common issue for running on Linux is problems with the video driver. There seems to be a few different types of video drivers that you can install, one is the built-in "nouveau" one and then there is the nVidia proprietary one. If you are using nouveau currently then you might try switching to the nVidia proprietary driver instead and see if that behaves better.
4409.46 In reply to 4409.45
Thank you Michael.
Actually, I have installed the propietary drivers.
On the other hand, I have started MoI from the console, and I have a bunch of messages (always the same) when I start:
fixme:win:EnumDisplayDevicesW ((null),0,0xe4f8e4,0x00000000), stub!
QWebInspector: QSettings couldn't read configuration setting [resourceTrackingEnabled].
fixme:win:EnumDisplayDevicesW ((null),0,0xe4dcc4,0x00000000), stub!
fixme:d3d:resource_check_usage Unhandled usage flags 0x8.
but, when I try to draw anything, I have a lot of messages of errors.
Example, if I draw a line:
fixme:imm:NotifyIME IMC_SETCANDIDATEPOS
fixme:imm:ImmReleaseContext (0x10072, 0x189048): stub
err:ole:marshal_object object doesn't expose interface {1430ab25-4fb6-44b9-8184-cce9ed3bd7d2}, failing with error 0x80004002
err:ole:ClientIdentity_QueryMultipleInterfaces IRemUnknown_RemQueryInterface failed with error 0x80004002
Maybe is better if I ask about that in winehq forum, ¿isn't it?
4409.47
I have trying more....
Each time I press the L-button, I get that (only with 1 click):
4409.48 In reply to 4409.46
Hi David, those messages are not really significant errors.
For example this one:
This message means that WINE does not implement the shell method that returns back whether there are any auto-hide taskbars set in the Windows desktop. MoI calls that method when you maximize its window to figure out whether to leave a little 2 pixel space on any side of the window where an auto-hiding taskbar is at, so that they can still pop up when you move the mouse to that side of the monitor.
There is not really any mechanism for auto-hide taskbars in WINE, so it's not really a problem that it does not implement that particular windows mechanism.
The other messages are similar - when you draw a line MoI will have some inter-process communication between moi_commandprocessor.exe where the script actually executes, and MoI.exe - that's what those ones like
are about, but that particular call is one that is again not an actual error, it's normal for this particular query interface call to fail in that particular instance.
So none of those messages that you show there seem like they are any particular cause for concern themselves.
Do you possibly have any kind of special anti-virus program also running that might be intercepting inter-process communication ?
4409.49 In reply to 4409.46
Hi David - I guess it could be possible that just the display of those messages to the console is itself taking some amount of extra time.
I'll see if I can tweak things a bit to avoid that level of chatter on the console, maybe that will help a bit.
How long of a delay are you seeing, is it something like a quick hiccup or more like a couple of seconds or what?
4409.50 In reply to 4409.48
Ufff, I'd like that those messages adviced that anything really important. At least I would have any clue.
I haven't got any antivirus program installed.
Maybe the graphic card is not powerful enough?
4409.51 In reply to 4409.50
Well, if I start MoI from the Icon -without console- I get more or less the same delay.
It's like a quick hiccup. The delay just for don't feel comfortable.
I have just opened a 14 mb file, and I perceive a more delay.
Almost all, when I put the pointer over an object looking for its "object snap" and then when I rotate in 3d viewport.
About this, in small files it doesn't flow fine (there are small leaps) but in the 14 mb files, the rotate is unhandling (big leaps and I can't control the moment to stop the rotation)
Show messages:  1-11  12-31  32-51  52-71  72-91  92-105
