Realtime (GPU-based) Nurbs Tessellation
All  1-9  10-15
4405.10 In reply to 4405.9
Hi Burr,
> Was there any way to get MoI any more than the 4 gigs?
No, not currently - 4 gigs (usually more like around 3.6 or so actually) is the most a 32-bit program can address.
But it does help a lot to run on a 64-bit OS though - on a 32-bit OS you'll actually only be able to get 2 gigs (more like 1.6 usually) actually allocated but if you're on a 64-bit OS there will be 2 more gigs available for MoI to use, provided you have that much RAM actually of course.
4405.11 In reply to 4405.10
Yeah, I only have 4 at the moment, but I did upgrade the OS to 64 bit, So will be adding more RAm for someother apps..
My current computer actually pushes to like 97/8 percent before MoI crashed... Something like 3.9 gigs or something... pretty good. :o
Maybe that was MoI with 3.6 and the other stuff using the other part.
4405.12 In reply to 4405.4
Are you saying that OpenCL would useful for things like arrays, but not much else? In MoI I mean.
4405.13 In reply to 4405.12
Hi southpaw,
Yeah, it's just more generally suited for processing big arrays of somewhat more primitive data. For the most part that doesn't really fit in with a whole lot of areas in MoI as compared to something like render engines for example.
4405.14 In reply to 4405.13
"Arrays" as in "groups of things".... Not the command "Array".
4405.15 In reply to 4405.14
Hi Burr - yup, that's "array" in the programming sense of the word.
Show messages: All  1-9  10-15
