Print 1:1
All  1  2-3
4399.2 In reply to 4399.1
I have made this in the past for the same thing ;)
Very more easy without script ;)
(don't refound the english version so here the translation :)
Décocher = disable
Pour une échelle de 100 = For a scale of 1 / 100
Draw a frame of 20 m * 28.7 (if scale is metter in SU) for be sure to have it in A4 format (21 * 29.7cm)
Disable Perspective in Camera view
In top view with A 4 format
Frame is well 20 * 28.7
Square is well 10 cm * 10 cm
Text frame is well 5 cm
Diameter is well 3. 68 cm
So Scale is good 1 /100
Just adapt for your own using ;)
EDITED: 25 Jul 2011 by PILOU
4399.3 In reply to 4399.1
Hi Alex - MoI does not itself have a 2D print function - to get better control over printing you generally need to export to a CAD program that has print functions and then those programs will usually have a lot of controls for the scale and stuff like that.
A couple of programs that can work well for that are Rhino (http://www.rhino3d.com/) or also ViaCAD 2D is an inexpensive option: http://www.punchcad.com/c-12-consumer-cad.aspx
It can be possible to do it with some view capturing in MoI though as well - see this previous thread for some details on how to figure out how large in units the width of a screenshot is:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4128.1
Show messages: All  1  2-3
