Meshing memory workflow
All  1-2  3-4
4385.3 In reply to 4385.2
Yeah, I wont need to send the dump (Unless you really want one).. It was the "second one" that creates the crash... I havnt had a crash on an out of memory situation.. It was when I hit that, then waited after canceling it, and trying to mesh "again", where the same settings that created the memory issue are presented and crash the MoI executable at that point.. Just knowing I shouldnt try to continue at that stage is good...
Maybe the out of memory error should carry that info with it, like "You should probably restart MoI now" kind of thing... :o
Anyway, thanks for the response.
4385.4 In reply to 4385.3
Hi Burr, if a dump was created, please do e-mail it to me since that may give me a clue as to what particular area needs some additional checks for out of memory handling.
I do try to fix those up when I'm able to - the difficult part is that there are many of them lurking around in different places and it's only when you run out of memory in that particular section of code that it will cause a problem.
So actually since it's a hard to reproduce problem sending the crash dump if it was generated would be helpful...
Show messages: All  1-2  3-4
