Sketch Tool
All  1-2  3-5
4364.3
Hi Michael, You're right, It must've been in between commands.
I did'nt notice the repeat option, I think this will actually help this situation, reducing chances of being in select mode inadvertently.
-> 2D illustration programs never transitioned from Beziers to NURBS
Expression 3.3 did have Bsplines, I think corel has it also.
Thanks!
Marc
EDITED: 4 Jul 2011 by TELLIER
4364.4 In reply to 4364.3
Hi Marc, I was able to get these sketch things tuned up for v3.
So for v3 once you have started a sketch brush stroke, if you right click during the stroke it will just be ignored instead of canceling the command like it does currently. If you right-click before you even start the brush stroke though it will cancel then.
Also in v3 when auto-repeat is turned on (when the little "Repeat" checkbox is checked) it should not matter how quickly you make brush strokes - currently if you do them too quickly it can exit auto repeat mode.
4364.5 In reply to 4364.4
Thanks Michael!!
Marc
Show messages: All  1-2  3-5
