Do you feel it?
 1-12  …  33-52  53-72  73-92  93-112  113-132  …  233-250
4363.73 In reply to 4363.72
lol... Instant "Ren" teeth!
4363.74
that is amazing stuff.
To do that with solid or any curves will really save time.
Denis
| CorelDraw Grahics Suite X5 | Daz Carrara Pro 8 | Moi 3D V2 |
4363.75
WOW it is good
Hi Michael can you make it to on curve and flat to surface (curve on surface)
and can you make a helix to flow the curve like that
v3 wish :sweeping profile and rotating at same time on a curve
EDITED: 11 Aug 2011 by BLYESS
4363.76 In reply to 4363.55
>I may need to do an overhaul of the surface rebuilding part to get the solid morphing piece to be more reliable.
Can you give us an example of warping a solid to 3D surface ?
Thank you
4363.77
Hi Michael
Besides WOW, I have just one comment... ;)
E.T.A.4.B.???
Cheers,
. d .
4363.78
Poor Michael.
It must be like looking out from inside a store front and seeing all these eager faces pressed up against the window, all wondering when you'll be done and open the door! ;)
Maybe we should all stop pestering the man so he can finish up! (Yeah, I'm impatient to see this bright shiny new version too...)
4363.79 In reply to 4363.75
Hi lyes,
You mean keeping it aligned with the surface normal? It doesn't do that currently but I'll give that a try and see if I can make an option for that.
Yup, helix works the same as any other curve:
4363.80 In reply to 4363.79
Sexy !!!!!!!!!!
4363.81 In reply to 4363.79
Cough! Cough! Cough! gag.... WOW!!!! :-D
That's amazing Michael - exactly what I was thinking of!
Could that be manipulated with a "Scaling Rail"? ...no... I ask too much. ;-)
EDITED: 11 Aug 2011 by MAJIKMIKE
4363.82 In reply to 4363.81
Hi Mike,
Probably for that you'd build a sweep with scaling rail applied so you had a kind of flat sweep surface shaped how you want your result, and then do a Flow with a surface to surface mapping instead of curve to curve mapping.
4363.83 In reply to 4363.76
Hi Anis,
At the moment I don't quite have the surface to surface mapping mechanism finished up yet.
4363.84 In reply to 4363.77
Hi Dee3,
> E.T.A.4.B.???
I'll probably need a couple more days to work on this new function and then I'll put out the new beta.
4363.85 In reply to 4363.82
Thanks Michael, your devotion to the product and the people that use it is commendable, can't wait to see the reports on the Beta. - take as much time as you need ;-) Inspiration breeds better than pressure.
But, I can't resist...
I'm sure this was asked many times before...
Is there a possible future consideration for some type of basic Free-Form Distortion, controlled by box bounds points?
Of course done by by warping the space that positions all spline curve and mesh point assemblies instead of poly vertexes.
I did see something before about dealing with the hidden point structures of each surface that would make it hard to do this, as they are often larger and occupy more space than the visible trimmed object.
4363.86 In reply to 4363.78
Greg,
""""""""""""Maybe we should all stop pestering the man so he can finish up! (Yeah, I'm impatient to see this bright shiny new version too...)"""""""""""""""
This is the beggining of the "Beta process" for the next version of MoI.. This is where we discuss the features and how they work and get a chance to input into the process.... It will most likely be awhile before the next version is done and released.
4363.87 In reply to 4363.86
This makes a great product - a fantastic product! Yup, I'm sure Michael would not be around if he didn't have the same collaborative spirit.
The good thing is, that V3 may be here in time for my financially challenged butt to save up the (small amount of) coin to purchase it. ;-)
I envy you guys that will get to test drive the V3-Beta into the outback to try and see what breaks the suspension!
4363.88 In reply to 4363.86
Hey BurrMan,
That quote was a (lame) attempt at humor having to do with our group impatience, not with the collaborative process. It must be very motivating to have people excited about your work, as apposed to sitting at a computer hour after hour without feedback (as some other developers seem to do). I honestly can't think of any other product (software) out there that I can talk to, and get immediate response from, it's creator. GO Michael! (I just wonder sometimes how he finds time to actually work on V3 AND be so responsive to every one of the threads on this forum!)
-Greg
4363.89 In reply to 4363.88
I have a mental picture of him walking down the street with some kind of Android or Blackberry tablet in one hand and a bagel and coffee in the other whilst talking to family and friends... at the same time fielding forum posts and simultaneously compiling code.
Hmm, actually my mental picture is now more about the bagel... a delicious toasted onion bagel with cream cheese and lox. :-p..
Ain't technology great!
4363.90 In reply to 4363.85
Hi Mike,
> points?
Yup, that could be possible in the future at some point - it would be a different tool than the one I'm working on now though, and that would also involve quite a bit more work since it involves interacting with a new set of points instead of just selecting existing objects.
For the most part I mostly assume that if you want to squish things around by manipulating 3D points that you would probably want to be working in a sub-d modeler for that particular kind of modeling rather than in MoI, since 3D point cage squishing is a major focus in those kinds of modeling programs.
MoI is overall more based on a different kind of modeling strategy of drawing curves to create objects, so focusing on a method that allows deformation by using drawn curves is more of an immediate natural fit for right now.
In the future I do want to add more point cage squishing type stuff in as well though, just not sure when though since there are also a lot of other things I want to add in as well too! :)
4363.91
Thanks Michael, I can't wait to see what you cook up!
Also,
Any chance of implementing something like this:
There is an amount of manipulation freedom and speed given to modeling when in one of the side projection views and the handles are present.
but it sure would be nice to have the same ability when you're in 3D mode.
I often find myself having to visit all of Top, Right and Front views when I want to scale "on the fly".
The handles are designed to appear only in a flat projection, but I see that the rotation controls are there also there in 3D mode... how'd he get so lucky?
What about scaling on the fly in the 3D view? --- I mean, to non-planar 3D objects.
(By the way - is there a command to turn the rotation rings gizmo on when I want without having to leave the 3D view to activate it on a flat view?)
Thanks!
4363.92 In reply to 4363.85
Hi Mike, by the way if you make a surface using the revolve command you can then turn on control points for it and manipulate them in sections giving you much the same kind of effect in MoI as what you posted in your animated GIF:
So that's something that you can try now if you want to squish a tubular type shape around.
Show messages:  1-12  13-32  33-52  53-72  73-92  93-112  113-132  133-152  …  233-250
