| Hi Burr, yup you can do multiple objects spaced along the base curve. Every object will get morphed into the equivalent area along the target curve. This usually involves some deformation of the object as well, like areas towards the inside of a bend will compress together and areas to the outside will kind of spread apart. I guess I'll probably put in an option like Rhino for just moving the object into that spot without the morphing too, although the non morphing version kind of seems like it should be some kind of "arrange" type function instead of being in a deformation function like this... not quite fully sure about that part yet.
