Do you feel it?
 1-9  10-29  30-49  50-69  70-89  90-109  …  250
4363.50 In reply to 4363.49
Hi NightCabbage, yup it's getting really close - I think I've got the selection filter system all working, and now I'm working on one of the first deformation tools, the "Flow" command which lets you warp an object between a base spine curve and a target one, like so:
4363.51
Hello,
Does this apply to solids as well? Even if not, I see could the immediate savings in time and effort using it.
4363.52 In reply to 4363.50
Nice Michael.
Can you lay that notched object down flat and deform it around the same curve?
If so, then we may need fewer steps to project designs and text onto a cylinder?
Ed
4363.53 In reply to 4363.51
Hi OSTexo, yes it will work on solids as well although with a few caveats. It seems like it will be better for sharp edged things - surfaces that were smooth to one another in the original object will not necessarily end up totally smooth to each other in the deformed result. That's because the surfaces undergo a kind of rebuilding process.
Still though it should be quite useful.
There will also be another variant where you can map a 2d layout from a plane to follow a surface rather than mapping from curve to curve.
4363.54 In reply to 4363.52
Hi Ed,
I'm not quite sure if I follow what you're asking about here - but there will also be a different variant that will allow you to map from objects arranged on a plane to some other surface rather than mapping between curves.
Yeah I think it should help out a lot for applying text on to other shapes.
4363.55 In reply to 4363.53
Also in some cases I'm seeing kind of odd little bumps and lumps in the rebuilt results when applying this to some kinds of surfaces. I may need to do an overhaul of the surface rebuilding part to get the solid morphing piece to be more reliable.
4363.56 In reply to 4363.54
Thanks Michael. I was asking if you rotate the notched object 90 degrees away from you (lay it down), will it wrap on the same curve?
Ed
4363.57 In reply to 4363.56
Hi Ed - sorry still not quite following - the notched object shown there is already a 2D curve laying flat in the Top view...
If I rotate it by 90 degrees then it will be sticking up vertically and you can still wrap it on that other curve - it will then give a vertical result like a wall like this:
4363.58 In reply to 4363.57
Sorry for the confusion. That's what I was trying to describe. Yes - that will open the door for a lot of design possibilities.
Ed
4363.59
Exciting looking stuff Michael! you're such a tease :)
4363.60 In reply to 4363.59
Ahhhh, text along path... Does it work with a 3d curve???
4363.61 In reply to 4363.60
Hi Burr,
It does - it's basically the same as doing a sweep with Twist:freeform along the curve.
4363.62 In reply to 4363.61
But with groups of object too???
4363.63 In reply to 4363.62
Hi Burr, yup you can do multiple objects spaced along the base curve. Every object will get morphed into the equivalent area along the target curve. This usually involves some deformation of the object as well, like areas towards the inside of a bend will compress together and areas to the outside will kind of spread apart. I guess I'll probably put in an option like Rhino for just moving the object into that spot without the morphing too, although the non morphing version kind of seems like it should be some kind of "arrange" type function instead of being in a deformation function like this... not quite fully sure about that part yet.
4363.64 In reply to 4363.63
Yeah... More like an array option......
4363.65 In reply to 4363.62
Hi Burr, here's an example with multiple curve objects (created from Text in this case):
Basically imagine that every point on each object is dropped down to the base curve (the horizontal line here) to see how far along that curve it is located at and what distance it is away from it. Then the it goes to the target curve and places that point at the equivalent location along the target curve.
The thing that's helpful about this is that some kinds of things are easier to draw with all straight and grid-aligned pieces initially and then morphed into their final shape rather than trying to draw them directly in their squished location from the start.
4363.66 In reply to 4363.65
Hi Burr yeah a non-morphing version would be kind of more like an array mechanism. Or maybe it's better described as an "arrange" or "distribute" type function since it is repositioning existing objects instead of repeatedly copying objects like array normally does.
The example I just posted above is a morphing one, note how the w in "with" kind of flexes outwards and the "cu" in "curves" kind of compress inwards.
But also note that in a case like this without any morphing the various things are likely going to collide into one another and overlap each other.
4363.67 In reply to 4363.66
I like the look of the example you just posted....
Maybe if there becomes arrange/distribute then arraygem goes with that....
4363.68 In reply to 4363.67
Hi Burr, but array gem does actually make a bunch of repeated duplicates of an object - that kind of repeated copying of an object is kind of what I'd put under "array" type functionality. But it's kind of all related stuff though too.
4363.69
Hello,
Would there be a parameter to determine how much stretching / distortion would occur to the original curve or object, maybe a min/max amount?
Show messages:  1-9  10-29  30-49  50-69  70-89  90-109  110-129  …  250
