Do you feel it?
 1-7  8-27  28-47  48-67  68-87  …  248-250
4363.28
Any chance circular selection method makes it into v.3?
4363.29 In reply to 4363.28
Hi Grendel - it's possible but it's not particularly high on the radar since circular selection hasn't really been mentioned very often as far as I remember.
If it's an important feature for you, put it on the Top 5 feature request list for v3 thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.1
Would you expect it to select things only entirely inside the circle or anything that touches the circle? Or would it be for selecting control points only?
4363.30 In reply to 4363.29
""""""""Would you expect it to select things only entirely inside the circle or anything that touches the circle? Or would it be for selecting control points only?""""
Personally I have looked for this when doing point editing.
4363.31
I would use it either to select inside or outside depending on the situation. I honestly do not use a lot of control point editing as I lean toward more mechanical things than organic product type stuff.
4363.32 In reply to 4363.31
Hi Grendel,
Could you describe a bit more about what you mean by selecting the outside? Instead of selecting everything to the outside, would it work to do a select all and then do a deselect with a circle selection tool to remove selection of things inside the circle?
Basically for regular selection of full objects there are 2 choices - should only objects that are completely contained within the circle be selected, or should any object that touches the circle even partially be selected?
4363.33 In reply to 4363.32
So a circular selection right to left touching or left to right strict similar rectangle selection existing ;)
4363.34 In reply to 4363.33
Hi Pilou, well probably a circular selection would be done with the first point at the center, not quite corner-to-corner like the regular rectangular selection.
4363.35 In reply to 4363.25
> so one thing I have to decide is whether filtering
> should only limit selections to the filtered items or
> whether it should limit both selection and deselection actions.
I'd always expect both selection and deselection, that's because all the other CAD programs I've used throughout my career work this way, the only difference between these and MoI is that the other programs use a modifier key with the mouse click to deselect.
4363.36 In reply to 4363.34
Yes :)
point the center then go to the Left = all touching the circular surface is selected
point the center then go to the Right = all inside the circular surface is selected
A circular 3D Selection? So a sphere selection ;)
Same above 2D Selection : just second click is Z Left/ Right selection
4363.37 In reply to 4363.36
Unfortunately this leaves the starting at the center and going straight up or down as indeterminate... That's kind of different with a rectangular selection since a corner-to-corner rectangle straight up or down is a degenerate flat line, but that's not the case with a circle.
So I'm not so sure that the same left/right mechanism fits quite as well with a circle from center point.... Maybe.
4363.38 In reply to 4363.37
The circle could be a corner to corner also.. And a modifier key would constrain a perfect circle.. So "elliptical" selection also!!
4363.39 In reply to 4363.37
< So I'm not so sure that the same left/right mechanism fits quite as well with a circle from center point.... Maybe
Why not : )
Seems a click center point + second click give all possibilities: circular surfaces or Spheres :)
4363.40
I was thinking
Select center point
drag for diameter
click
arrows bracket the circle line inside and out
click inner to select inside circle, click outer to select outside
the circle would affect anything inside or touching....or outside and touching if an outside selection is needed
4363.41 In reply to 4363.39
The filter sounds great, looking forward to try it!
In some situations locking the solids only will be nice to prevent accidental sub-object selection.
Marc
4363.42 In reply to 4363.40
Hi Grendel,
The problem with that, is that extra inside/outside step would be really inconsistent with how other selection tools works.
Like for example if you do a rectangular selection right now, there isn't any extra stage to do that kind of inside/outside step - instead the way you do that with the rectangular selection is to first do a "select all" and then do a rectangular selection but hold down the ctrl key which makes it do a deselection of the things captured by it, that produces a rectangular hole in the selection.
It's good if other kinds of selection tools would work in a more consistent manner to the existing ones, rather than having a really different kind of flow to them like the arrow bracket inside/outside step like you've described here...
4363.43
I love these threads where Michael is explaining his rational for features, specifically:
"Things like a permanent extra button means that some beginning user who just wants to do simple things and doesn't need to do any filtering will pay some price in UI complexity for something that they don't use. That's the kind of thing I'm trying hard to avoid."
Implied in this is an often overlooked psychology principle, hierarchy of knowledge and its unconscious effect on emotions, which is required for efficient teaching/learning.
Its at once disheartening and exciting to see that while my University professors are forgetting it, Michael is actively employing it in the indirectly related field of UI design!
I believe that its such things, considered small by modern standards of judgment, that are the reason why many people are grappled by MOI, at first emotionally and then intellectually.
4363.44 In reply to 4363.43
Thanks Ambimind!
Yeah, often times the negative consequences of adding stuff to UI is not really considered very carefully by many developers, that's a big reason why typically a program becomes sort of "bloated" over time.
Trying to avoid that is a big priority for MoI's continued development.
One way that I do that is by trying to get more multiple functions out of the same UI area - like in this case for filtering the selection indicator will do double duty to also allow for filtering as well. I try to make it a higher priority any time there is a good concept on how to re-use some existing UI to make it more powerful without really adding any extra footprint to the simple use case.
4363.45
Hehe this is great :)
But yes, I'm really keen to see circular selection - many times so far I've wished to have it!
4363.46
If that is not possible then making a circle that selects everything touching inside is simple enough and then I can invert selection to get the outside
4363.47
Today I feel it very strong, it seems, hour X comes nearer.
Rudl
Show messages:  1-7  8-27  28-47  48-67  68-87  88-107  …  248-250
