I knew somehow this one seem to easy. I tried sweep as you suggested but it is almost as complicated because in order for the button to fit on the original target surface, I have to create each curve for the sweep exactly the same length of the side of the base plane, this prevents any scaling (still have to flip normal). Lastly for some reason the button get rotated about the normal of the 2 curve used for the sweep where they intersect (see joined image, red line). Just in case, I've rotated the button, the seam was vertical where the curve shows at the top of the surface.
> Do you mean having some special option just for the convenience of a couple of less clicks?
No, I was thinking more of something like a custom script and I think I can create it myself someday (and share it).
I have a passion for furniture making and I'd like to add ornaments or carving like features to my work and not just glue on type of ornaments. This new flow command is just great for that and yes many time the target surface will be flat but there will also be quite a lot curved surface as well (legs, corner post, etc.) and somewhat less compound curve surface as in this case.
The simple button I've used here is just a proof of concept kind of thing I used to learn how to use this new flow command. Eventually, I intend to also use highmap displaced surface via Zsurf probably and use flow to make it conform to the surface I want.
Moi moi moi, I'm getting adicted...
Felix
![](get_attachment.php?webtag=MOI&hash=617316ac4b0929df889a3ea36efc74ec&filename=flow-test03.png)
