Do you feel it?
 1-8  …  169-188  189-208  209-228  229-248  249-250
4363.209 In reply to 4363.204
Hi Danny,
> Another thing I've noticed Michael, the icon fonts seem a little
> different to V2 and the Icons themselves seem to be softer or
> is that just me?
It uses the same mechanism as v2 for scaling the icon images... But possibly the font size of the UI is slightly different than v2 on your system making a slight change in appearance with things like 2 pixels bigger or smaller.
Could you please post a screenshot of both v2 and v3 so I can see the difference? Please use PNG format to avoid any JPEG compression fuzz.
4363.210 In reply to 4363.203
Hi Marco, thanks for the UI size video. I seem to remember having a similar problem at one point before and I thought that I had gotten it fixed but apparently not all the way. Something to do with a timing issue for when the slider gets initialized. I'll examine it and see if I can get it fully solved for the next beta.
Are you use you don't want to leave the UI at size 30? That makes it really easy to read the text! ;)
4363.211 In reply to 4363.209
I had commented that I noticed it too... I was following through with your request to Danny and noticed that it was actually being drawn BETTER!!! (No different font or size.)
I dont know if this screengrab is large enough to show it.. V2 is on the right, V3 is on the left
Maybe the "difference we see, is that we are seeing a "Clearer" picutre of whats there??
EDITED: 26 Aug 2011 by BURRMAN
4363.212 In reply to 4363.202
Hi Felix, re: flow question
> I assume something can be done to put the ring on the
> outside of the rounded surface.
For now you can either sink the ring down to the bottom of the plane surface, or you can select the rounded surface and run the Flip command on it to flip its positive surface normal direction to the opposite side:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#flip
Right now surface-to-surface flow will use the positive surface normal direction of the surface for the mapping, and with open surfaces this can often be pointing in a way that you didn't really expect - it's dependent on things like what direction (clockwise or counterclockwise) you drew some of your initial curves in or things like that. If you make things into a solid then it will orient surfaces to have the positive normal direction pointing to the outside of the solid.
> Also, as you can see both surface have the same Y length,
> so I expected the ring to have the same Y value as the original
> and since in the X direction the surface have different length
> I expected the ring to be strech.
So what is happening here is the U and V directions of the rounded surface are swapped from what you're expecting.
Every surface has a kind of UV space associated with it, similar to how texture mapping works in rendering. One direction of a surface's control point grid is the U direction and the other direction is the V direction. They're not really forced to be aligned in any special way to the world axis directions.
Flow actually maps things from one UV space to another UV space, it doesn't really map things in world x/y/z axis directions - the directions all come from this UV space.
So in this case the U direction of the plane is the horizontal one, but the u direction of the surface is the vertical one it ends up mapping from one direction to the other causing this distortion.
Right now I don't have any way set up to swap the UV axis directions so the solution right now would be to squish the plane so that it was horizontally the size that you wanted to map to the vertical direction of the rounded one.
> I think for cases like the first example, it would be nice to
> have somekind of option to flip the ring to the inside/outside <...>
Yeah I want to make some way to control it - that's an area that I still need to work on adding to the Flow command, I just didn't want to delay the beta any longer before finishing that up.
I'll probably be trying to make it work by paying attention to which corner you click nearby on each surface when you select them and then matching those corners together, that should make it so that you won't have to worry about u and v directions anymore.
For curve to curve flow that works already - it matches things starting with the ends that you clicked closest to but I didn't finish the equivalent thing for surface to surface flow yet.
4363.213 In reply to 4363.211
Hi Burr, so it does look there like a different font is being used - notice for example the 'a' character in "Draw curve" is a different glyph between those 2 screenshots.
Some change in font detection code in v3 apparently thinks that you don't have the Century Gothic font installed, that's the difference, so it's defaulting to Arial instead of the regular default font.
If you want v2 to look the same way, go to moi.ini and set
[UI]
UIFontName=Arial
and then it should look the same between the 2 versions font-wise anyway - can you give that a try to verify that?
4363.214 In reply to 4363.213
Yeah, the V3 was set to arial.. Setting them both to match made them equal...
Is there anything you want to know about my century gothic?? Like there are different values for display and embeddability attributes.
For arial I have "text" and for century I have "display" for the catagory and for font embeddability I have "editable" for arial and "installable" for century gothic...
Anyway, lett me know..
4363.215 In reply to 4363.214
Hi Burr - re: century gothic - maybe what I will do is send you a couple of small test programs through e-mail and if you can run those to test if your Century Gothic is detected or not with a couple of different techniques.
But I'm not too worried about this issue at the moment, maybe we can wait until next week to try that?
4363.216 In reply to 4363.215
Re: fonts
What Burr is getting there is the same as on my computer I think I prefer century gothic.
BTW was your server down for most of the day ?
4363.217 In reply to 4363.216
Yeah, the whole day I tried MoI Forum but looks like server down :(
4363.218
Good to see the site back up and running. Downloading V3 beta now. Looking forward to having a play with it.
Nigle / 3DKiwi
Homepages: 3dkiwi.co.nz & C4D Cafe
4363.219
Word got out about the V3 beta and everyone tried to get it at once! (Oh to be so popular!)
4363.220 In reply to 4363.212
I use flip on the rounded surface and the ring appeared on the right side of the curve but it is still stretch in V direction. I assume as you mention, it because the UVs are orthogonal from the base to target surface.
Since you already have the orientation picker would it be possible to use that to orient the UVs of each surface as you like (as an option maybe), this would provide maximum flexibility, ie. the UVs of base surface could be setup say north/south and the target UVs could be oriented north-est/south-west or whatever. If HISTORY was available one could even modify the original object by whatever mean. (control points, move, scaling, etc) and see in real time the effect on the final object. This would give us awsome creative potential.
Felix
PS. I tried history and it doesn't apply (unless it's me) and I tried to orient indirectly the UVs by rotating the surface, it works only in 90 degree steps sort of speek. Conclusion: history would be a big plus.
4363.221 In reply to 4363.216
Hi Danny,
> Re: fonts
I should be able to get that figured out for the next beta.
Yup, power outage in the data center. I guess they had to go to every machine in the whole facility and manually reset them so it took a while to get things going when the power returned.
4363.222 In reply to 4363.219
Hi Greg,
At first I thought maybe my poor web server was getting overloaded like that! But actually it was sitting there without any power due to a power outage in the data center...
4363.223 In reply to 4363.222
For avoid that! :)
4363.224 In reply to 4363.223
lol Frenchy... "I'll peddle!!!"
4363.225 In reply to 4363.220
Hi Felix,
> as you like (as an option maybe), <...>
I don't think it will be feasible to do that - for things to work well it needs to map from one full UV space to the other UV space and although it will be possible to do something like map U to V or U to negative U or things like that it won't work to do something arbitrary like a 30 degree angle which is what the orientation picker is set up to allow currently.
I think the way I'll be able to make it work is that it will pay attention to which corners you click nearest to on both the base surface and then the target surface and then flip or swap UVs as necessary so that those 2 corners align. Then maybe a checkbox for flipping the surface normal direction.
That should give you some control over how the base surface and target surface will align with one another without needing to worry so much about which particular directions are the U and V directions.
If you want to rotate something by some arbitrary amount, you would need to do that by either rotating the object or the base plane how you want it first before doing the Flow.
History is not on by default for Flow but you can turn it on by selecting the output object (the deformed result) and then using the Edit > History command, and click the "Enable update" button.
When history update is enabled on the result object then it will recalculate when you edit either the original object or either of the 2 surfaces.
4363.226 In reply to 4363.225
Thank Michael,
I tried history as you mention and it works fine. It give you quite a bit of possibility.
At least the idea of flipping the normal using a check box wasn't a bad idea after all.
Thanks again,
Felix
4363.227 In reply to 4363.226
Hi Felix,
Yeah that part should probably be fine.
The thing that could get sort of messy would be if there were 3 checkboxes like "Flip U", "Flip V" as well as "Flip surface normal". That's getting to be kind of a lot of flip options and you may not even know in advance which particular direction is the U and which is the V.
So that's why it could be better if the U and V alignment could be done by paying attention to where you clicked on each surface to - it could flip U and V directions as needed so that the corners that you clicked on would get aligned to one another.
That's what I think I'm going to try anyway, we'll see if it will work out ok or not.
4363.228 In reply to 4363.227
>The thing that could get sort of messy...
that's why I though of the orientation picker as a mean to setup the UV's like you want but maybe, instead, if it's possible of course, would it be possible (completely outside the flow command) to kind of see the normals orientation and or the UVs orientation? We could setup thing before hand.
I've done another test and I think it's easy to figure out what I'd like to have instead of the result I got (see file). I would like (if possible) the flowed object to keep as much as possible it's roundness. Though I can see other ways to do that, I wonder if I could still do it using flow which would be much less work especially when the object to be flowed is much more complex than the current one?
Edit: I got it, I created a trimmed surface from a projected circle (on the original target) of the proper diameter and I needed to shrink the trimmed surface and the result look much better now. But the roundness is still distorted, to a much less degree though. I'll try another mean to create the target surface, maybe a bool intersection??? No, still have the same untrimmed surface. Is there a way out???
Felix
EDITED: 26 Aug 2011 by FELIX
Show messages:  1-8  …  149-168  169-188  189-208  209-228  229-248  249-250
