Do you feel it?
 1-5  …  146-165  166-185  186-205  206-225  226-245  246-250
4363.186 In reply to 4363.176
And official winner of 1st download goes to gbing!
4363.187 In reply to 4363.182
Hehe !
I've never been very far. ,-)
Most of the time I'm reading the posts on the forum as a guest but I never stopped to use MoI and it's really cool to start a new beta period.
Right now I'm trying the new flow command...
(Re : >> I can tell you that variable radius fillet has been requested quite a lot so I do expect to work on that.)
Great !!!
Cya
Bernard
Happy MoI user since beta version of August 13 2006...
4363.188 In reply to 4363.187
I was looking for the announcment.. gbing just went to download page and... RATS... Foiled again... Someday.. Someday...Gotta be quick in THIS forum!!!
Michael,
This line seems to no longer present the image listed as the source in the plugin gallery..
<moi:PushButton command="ToroidalHelix">
img width="160" height="120" src="helix.JPG"
div ToroidalHelix div
Creates a helix.
</moi:PushButton>
Is there a change to have the image displayed??
I made a couple changes to the line I had been inserting into the sidepane.htm, to have it match the others and it worked OK. Just removed a "style" and couple other little differences...
4363.189 In reply to 4363.188
Wow.... I wasnt expecting "Rigid" in the new flow command... That worked great!!!
4363.190 In reply to 4363.189
Opihi on the rocks!!! Ala the new flow command...
And with that, I'm going to bed...
4363.191 In reply to 4363.185
Hi Rudl,
> On my system it seems to run normal. It took the options
> from V2, so that my first thought was, I have installed v2.
That's good news - that's how it is supposed to work.
> Didn´t find out how flow functions.
You've got to set up both a base backbone curve (usually this will be a line), and then a target curve to use as the new backbone.
Start by selecting the objects that you want to modify. Then run the Flow command, pick the base backbone curve and then pick the target one.
Check out the attached flow_example.3dm file.
Load up the file and then select just the text so that it looks like this:
Then run Transform > Deform > Flow, then click on the line, then click on the wiggly curve above and you should get this result:
You can kind of think of the original line as a "starting spinal column" for the text. The flow command allows you to map objects between a starting spine to a different shaped spine. You can also map between surfaces, with a starting plane mapping to a bendy surface.
Works fine on my old computer!
Bravo!
4363.193 In reply to 4363.186
Hey, thank you Michael!
I hope to use MoI in next days more than in past months.
My first impression is very good and I think that with deformation tools like flow MoI will become very useful for complex Architecture.
Bye,
Giovanni
P.S. I had a problem in the last couple of months with V2: at start no icons was present; I need to reduce window and then maximize (I suppose a problem with latest driver or with some windows update) - with V3 no problem!!
4363.194 In reply to 4363.188
Hi Burr,
> Michael,
It looks like your post there is getting kind of mangled by the forum because it will think that you're trying to use that HTML as part of your message.
Try putting any code like that inside of a <code> ... </code> block here in the forum - that will prevent the forum from trying to actually use the HTML for your message itself. Or maybe it's best to post what you've got as a file attachment that way I can look at it more directly.
Oh wait a second, I know what it is - at the moment JPG files won't work in an <img> tag like that, save it as a PNG file and then it will work. I can fix that up pretty easily for the next beta, I forgot about that part because I only use PNG myself.
> differences...
Yeah there are a few changes in how various controls are structured - for example a <moi:CommandButton> takes its image as an icon="" attribute instead of on the style. And actually <moi:CommandButton> is a template now - you can see the template that makes it up in the file CommandButton.htm . The part that says icon="..." goes into an <img> tag that's part of the button structure.
Things like icons are now drawn by more regular <img> tags now (sometimes in templates) - before they used to be drawn by custom painting code.
Basically instead of a control being painted by custom code, they're now assemblies of HTML with stuff like images and divs with gradient backgrounds and stuff like that. The main exception is the scene browser, it has some custom painting code in it.
4363.195 In reply to 4363.192
I have no icon for "deform" and "flow command" and the previous customization weren't used.
But it works great.
Luca
4363.196
Thanks Michael.
Maybe you should start another thread specifically for V3 beta testing related stuff.
4363.197 In reply to 4363.193
Hi Giovanni, yeah Flow should allow for quite a lot of curvy bendy things that would have been pretty difficult to create before.
This was due to some glitch introduced in Internet Explorer v9 - I'd bet that it started happening after IE9 got installed on your system.
That's a pretty good example of why I wanted to move to a different system for the UI.
4363.198 In reply to 4363.195
Hi Luca,
Yeah that's normal - I just haven't made the icons for those yet.
That's also normal for the time being - any custom commands that you installed for v2 need to get copied into the v3 \commands folder. Tomorrow I'll post a utility program that will help with doing that.
4363.199 In reply to 4363.196
Hi Danny,
Yeah I need to do the official announcement thread... Coming up in a moment.
4363.200
Hi Michael
..some glitches here and there:
- UI-size skips instantly to 30, if the fader is moved (actually, MouseDown on the fader does trigger it)..after that, fader has no effect what so ever..manual entry does work though
- Long object names in the Browser (might be normal behaviour..)
cheers&good job&best of wishes,
Marco
P.S. I'm on Win 7 64bit
4363.201 In reply to 4363.200
Hi Marco thanks for the bug report!
Unfortunately I can't seem to repeat this one over here, I'll keep trying on a few different systems.
I may need to add some kind of extra debugging output to the next beta to try and track this one down.
Yeah I wasn't quite sure whether to leave that or not because it is kind of good with long names to see as much of the name as you can.
But it's pretty messy having things draw over top of each other like that.
What about a kind of hybrid behavior - if there wasn't any selection dot there at all then I could let the text run into that selection dot area, but if there is a dot displaying then the text would get truncated before the dot.
The other option is to have it always truncated leaving the dot as a completely separate column but that means the selection dot will have reduced the display space for the text name in all cases.
4363.202 In reply to 4363.191
first, congratulation for V3! The new interface (UI) seems to work just fine.
I've tried the flow command on the file you provided and it working as expected. I then tried a surface to surface flow and here is what I get (Flow-test001). My intention was to deform a medallion from a flat surface to a rounded one. So I started simple but I didn't get what I was expecting. I assume something can be done to put the ring on the outside of the rounded surface. Also, as you can see both surface have the same Y length, so I expected the ring to have the same Y value as the original and since in the X direction the surface have different length I expected the ring to be strech.
Just to be on the safe side, I tried to make sure both surfaces had the same X and Y dimensions and this time I got what I wanted. (Flow-test002)
I think for cases like the first example, it would be nice to have somekind of option to flip the ring to the inside/outside and it maybe nice to have control over which direction (X,Y, maybe Z and XY, XZ, YZ, etc.) to stretch things beside having to do it by carefully (re) creating both surfaces.
Thanks and congratulation again,
Felix
4363.203 In reply to 4363.201
Hi Michael
UI-size-thingy:
http://www.screencast-o-matic.com/watch/cXjZXa3uw
or
Truncate:
..thats really a tricky bit of usability-issue.
Normally i would vote for an Ellipsis (…) (bold or somehow visually enhanced) ..eventually a Guillemet (»)..but sometimes you have to deal with generated names and then this approach might not work as intended.
Cheers,
Marco
EDITED: 24 Aug 2011 by MARCO
4363.204 In reply to 4363.201
> What about a kind of hybrid behavior.......
> leaving the dot as a completely separate column...
My vote is for either method as long as the name doesn't end up under the indicator dot.
Another thing I've noticed Michael, the icon fonts seem a little different to V2 and the Icons themselves seem to be softer or is that just me?
4363.205 In reply to 4363.204
< seem to be softer or is that just me?
Maybe default screen regulates lights are not the same than your V2?
Show messages:  1-5  …  126-145  146-165  166-185  186-205  206-225  226-245  246-250
