Do you feel it?
 1-18  …  139-158  159-178  179-198  199-218  219-238  239-250
4363.179 In reply to 4363.176
And it's out - http://moi3d.com/beta.htm - linked to from the download page.
Brief overview:
New Flow command (Transform > Deform > Flow, no icon yet) for deforming objects from one "backbone" to another, see previous examples in this thread.
New selection indicator in the scene browser - shows a yellow dot on the right hand side to show if an item has selection or not, also now click on that spot to select or deselect things in the scene browser. Also you can use Ctrl+click on that same spot to set a selection filter which is also new.
Major overhaul to many internals - the UI is now based off of WebKit/JavaScriptCore instead of mshtml.dll/JScript.dll , updated to new OpenNURBS v5 library for reading 3DM files - this enables reading of Rhino v5 files and should round trip stuff like extended layer properties to Rhino v4 better. Also updated to the newest release of the Solids++ geometry library which has some various bug fixes in it. There may be some regressions due to all this various library churn, let me know if something that worked in v2 doesn't seem to work in v3.
4363.180
Downloaded and installed...
Now let's play. :-)
I've been using MoI for almost five years now and it's always been a pleasant experience.
Thanks Michael for making MoI such a joy to use.
Happy MoI user since beta version of August 13 2006...
4363.181
Thank you.
Let´s start playing.
Rudl
4363.182 In reply to 4363.180
Thanks Bernard, it's good to hear from you again! :)
Is it able to start up and appear to run normally on your systems?
There have been a lot of changes in this version to how the UI and script system works internally, so it would not be too surprising if there were some glitches to work out.
Ultimately though having more of the UI code more self contained like it is now will help with stability in the long run since there will be less variation between systems.
4363.184 In reply to 4363.183
Looks good so far here.. I did all my custom additions and I view no difference...
Just reviewing the sidepane.htm at the moment.. It seems to handle "icon" a little different???
The text in the line does appear slightly changed. I will poke around and ask if I cant figure it out...
4363.185
On my system it seems to run normal. It took the options from V2, so that my first thought was, I have installed v2.
Didn´t find out how flow functions.
Rudl
4363.186 In reply to 4363.176
And official winner of 1st download goes to gbing!
4363.187 In reply to 4363.182
Hehe !
I've never been very far. ,-)
Most of the time I'm reading the posts on the forum as a guest but I never stopped to use MoI and it's really cool to start a new beta period.
Right now I'm trying the new flow command...
(Re : >> I can tell you that variable radius fillet has been requested quite a lot so I do expect to work on that.)
Great !!!
Cya
Bernard
4363.188 In reply to 4363.187
I was looking for the announcment.. gbing just went to download page and... RATS... Foiled again... Someday.. Someday...Gotta be quick in THIS forum!!!
Michael,
This line seems to no longer present the image listed as the source in the plugin gallery..
<moi:PushButton command="ToroidalHelix">
img width="160" height="120" src="helix.JPG"
div ToroidalHelix div
Creates a helix.
</moi:PushButton>
Is there a change to have the image displayed??
I made a couple changes to the line I had been inserting into the sidepane.htm, to have it match the others and it worked OK. Just removed a "style" and couple other little differences...
4363.189 In reply to 4363.188
Wow.... I wasnt expecting "Rigid" in the new flow command... That worked great!!!
4363.190 In reply to 4363.189
Opihi on the rocks!!! Ala the new flow command...
And with that, I'm going to bed...
4363.191 In reply to 4363.185
Hi Rudl,
That's good news - that's how it is supposed to work.
You've got to set up both a base backbone curve (usually this will be a line), and then a target curve to use as the new backbone.
Start by selecting the objects that you want to modify. Then run the Flow command, pick the base backbone curve and then pick the target one.
Check out the attached flow_example.3dm file.
Load up the file and then select just the text so that it looks like this:
Then run Transform > Deform > Flow, then click on the line, then click on the wiggly curve above and you should get this result:
You can kind of think of the original line as a "starting spinal column" for the text. The flow command allows you to map objects between a starting spine to a different shaped spine. You can also map between surfaces, with a starting plane mapping to a bendy surface.
Works fine on my old computer!
Bravo!
4363.193 In reply to 4363.186
Hey, thank you Michael!
I hope to use MoI in next days more than in past months.
My first impression is very good and I think that with deformation tools like flow MoI will become very useful for complex Architecture.
Bye,
Giovanni
P.S. I had a problem in the last couple of months with V2: at start no icons was present; I need to reduce window and then maximize (I suppose a problem with latest driver or with some windows update) - with V3 no problem!!
4363.194 In reply to 4363.188
Hi Burr,
> Michael,
It looks like your post there is getting kind of mangled by the forum because it will think that you're trying to use that HTML as part of your message.
Try putting any code like that inside of a <code> ... </code> block here in the forum - that will prevent the forum from trying to actually use the HTML for your message itself. Or maybe it's best to post what you've got as a file attachment that way I can look at it more directly.
Oh wait a second, I know what it is - at the moment JPG files won't work in an <img> tag like that, save it as a PNG file and then it will work. I can fix that up pretty easily for the next beta, I forgot about that part because I only use PNG myself.
> differences...
Yeah there are a few changes in how various controls are structured - for example a <moi:CommandButton> takes its image as an icon="" attribute instead of on the style. And actually <moi:CommandButton> is a template now - you can see the template that makes it up in the file CommandButton.htm . The part that says icon="..." goes into an <img> tag that's part of the button structure.
Things like icons are now drawn by more regular <img> tags now (sometimes in templates) - before they used to be drawn by custom painting code.
Basically instead of a control being painted by custom code, they're now assemblies of HTML with stuff like images and divs with gradient backgrounds and stuff like that. The main exception is the scene browser, it has some custom painting code in it.
4363.195 In reply to 4363.192
I have no icon for "deform" and "flow command" and the previous customization weren't used.
But it works great.
Luca
4363.196
Thanks Michael.
Maybe you should start another thread specifically for V3 beta testing related stuff.
4363.197 In reply to 4363.193
Hi Giovanni, yeah Flow should allow for quite a lot of curvy bendy things that would have been pretty difficult to create before.
This was due to some glitch introduced in Internet Explorer v9 - I'd bet that it started happening after IE9 got installed on your system.
That's a pretty good example of why I wanted to move to a different system for the UI.
4363.198 In reply to 4363.195
Hi Luca,
Yeah that's normal - I just haven't made the icons for those yet.
That's also normal for the time being - any custom commands that you installed for v2 need to get copied into the v3 \commands folder. Tomorrow I'll post a utility program that will help with doing that.
Show messages:  1-18  …  119-138  139-158  159-178  179-198  199-218  219-238  239-250
