Special "point on a curve" editing
 1-2  3-22  23-30
4338.23 In reply to 4338.22
""""""""""But there would also be some option to turn that off and use its control points as well.""""""""
Or "BOTH".... :)
I dont have solidedge.. I was just referencing that as an example, so I cant really test how it is handeling all the situations...
But, You've answered a good workflow for me...
4338.24 In reply to 4338.23
Both at the same time isn't very good because they edit the curve in different ways - it would be ok for just dragging one single point of either type but building up a multiple selection of points that included some "on curve" points and some regular control polygon hull points at the same time and then doing a transformation on that multiple selection would not make sense.
4338.25 In reply to 4338.24
Hi Michael, this is what originally sparked my interest...
http://youtu.be/g-Q_jaqg5fc
You can just go to 4:40 of the video and look for about 30 seconds to see what i was refering to...
But I like MoI's with the "pick any point" on the curve better....
4338.26 In reply to 4338.25
Hi Burr, I suppose those are probably knot locations being displayed on the curve.
But notice in the video that with the 2 kinds of points displayed at the same time he only ever drags on a single point to do the edit? (or at least in that particular spot of the video).
Moving just 1 point is fine for many situations, but it can also be useful to grab a whole set of control points with a window select and move all of them in one operation.
But doing multiple selection of both kinds of points (both "on curve" points as well as control polygon points) is going to be problematic because each kind of point needs to do a different kind of edit to the curve, you can't do both types of editing at the same time.
Maybe they do something arbitrary like just ignore edit points if there are also control points selected or something like that - but it tends to be far better to avoid having ambiguous situations in the first place.
4338.27 In reply to 4338.25
The nice part about it is that you can tweak any part of the curve that you want to, rather than only being able to grab certain locations...
4338.28 In reply to 4338.27
I was thinking that you had said that only showing one or the other and not both at the same time, as in the video. But now that you bring that up, I can see how this could be problematic with "selecting an oncurve point along with a hull point" at the same time.... Good note..
Thanks again for looking at this.....
related with all this :)
Does it possible to "join" a point to a curve even this last is moving when control points of the curve are moving?
Actually a point is not "joined" even you uses the command "join" !
4338.30 In reply to 4338.29
Hi Pilou - the Join command knows how to join curves together into larger composite curves or surfaces together into multi-face or solid objects. There is no functionality in Join for joining a point to anything else.
I guess you want to have a kind of "Persistent point on curve" - a point that is located at a particular parameter value of a curve and moves with the curve when you edit it? MoI does not currently have anything set up for that.
Show messages:  1-2  3-22  23-30
