some vertex maps show as black/bubbly artifacts in Modo
All  1-2  3-5
4316.3 In reply to 4316.1
Hi gustavo, the other reason why there isn't a "backface" type display in MoI is that for a long time I assumed that could be done in a polygon modeling program, since every polygon modeling program seems to have a flip function in it.
Unfortunately many of them seem to be broken when flipping meshes with vertex normal data attached to them. Is that still a problem in Modo now?
Could you ask them to fix that up? It's a pretty simple thing - if you flip a mesh that has vertex normals, it should flip the vertex normals as well.
4316.4 In reply to 4316.3
thanks Michael, I will ask, and let you know if this gets fixed on their end.
4316.5 In reply to 4316.1
Have you tried : Geometry-> Vertex -> Merge...
Not the "Merge Tool".
You may need to run the tool a second time.
Also, if there are any left(There are usually no left-overs if I use LWO format for export):
1 - In polygon mode, with nothing selected: press F two times( I don't know why this works, but it does).
2 - Polygon-> Align.
3 - Sometimes there are still strays left over, in this case you must flip them individually(even if their normal is facing outwards) and apply Polygon -> Align
EDITED: 2 Jun 2011 by AMBIMIND
Show messages: All  1-2  3-5
