Sweep Bug?
All  1-10  11-12
430.11 In reply to 430.8
Hi Konstantin,
As long as I use MoI, I never face those problem.
Try to use different username when login to Windows.
430.12 In reply to 430.10
Hi Konstantin, well you certainly have plenty of memory available, so that's not the problem.
I don't really know what is going on, but I can tell you that is an unusual problem.
Could you try the alternate trial version from here:
http://moi3d.com/2.0/trial/moi_v2_nosave_trial_setup.exe
and see if that works better or if it has the same problem?
The regular 30-day trial has this anti-hacking layer around it, and that is fairly complex, it could be part of the problem, the alternate trial version does not have that.
Also you might try disabling Kaspersky completely temporarily and then try running MoI, instead of just putting MoI on its whitelist. That's a little suspicious that is installed on both your systems and you're having the same problem on each.
Show messages: All  1-10  11-12
