Possible glitch??
All  1-10  11
4290.11 In reply to 4290.10
Michael,
"You can actually just do an extrude if you want - extrude each curve out to a surface and then select the 2 surfaces and run the Isect command. That way you will be able to get the full Extrude interface because you'll really be using Extrude."
that's exactly what I meant and better yet, it's already implemented. A little but though, there is no way to figure this out from the help files...
Felix
Show messages: All  1-10  11
