Simlab composer 2.3
All  1-6  7-11
4289.7 In reply to 4289.6
Comment puis je avoir accès à la traduction depuis la version 2.3 initiale? Dois je telecharger à nouveau Composer ou existe il un patch ?
Merci Pilou pour la traduction.
4289.8
4289.9 In reply to 4289.7
:D
@ Grandpi
I suppose yes reload can works but i will ask that because there are maybe some overwriting of new files that you can have builded in path arborescence!
Your original works for example!
So wait a day please :)
For the French Manual : sure but in a few days ;)
EDITED: 21 May 2011 by PILOU
4289.10 In reply to 4289.7
@Grandpi
OK the news ! ;)
The user has two options:
A- Uninstall SimLab Composer 2.3 and install the new version with French translation, this should not overwrite existing files.
or
B- Copy this file French_translation.qm
from https://www.yousendit.com/download/dkJwTXRYcHY4NVd4dnc9PQ
to C:\Users\”user name”\AppData\Roaming\SimLab\data\languages, next time SimLab Composer will detect the new language and the user can switch the interface langugage.
Je pencherais pour la 2ème solution, comme cela aucun risque! ;)
Ou alors la première mais en doublant les fichiers de travail résultants se trouvant dans les arborescences, à un autre endroit, au cas où! :)
EDITED: 22 May 2011 by PILOU
4289.11 In reply to 4289.10
impeccable !!!.
Merci Pilou.
Show messages: All  1-6  7-11
