Clean 2D Export Apps?
 1-17  18-37  38-47
4277.38 In reply to 4277.37
I've always thought Xara was more focused on vector drawing. It's pretty nice - just kind of generally slick and nice UI. Definitely worth checking out at least.
4277.39 In reply to 4277.37
Hi Ostexo
I often stack raster screenshots from Moi and use it as a quick base for the illustration.
A simple example:
There are numerous not so obvious small workflow details that make Xara real efficient on day to day use.
I find a general behavior consistency across many type of functions, for example the gradient and transparency tool are very much alike.
The fast real-time dragging aspects of many tools; gradients, feathering, transparencies is awesome .
You can apply transparency to individual objects, group them and apply another transparency level to the whole group and repeat this as many times you like..
Other cool details I can think of that I find quite usefull:
Toggle "selection tool/last tool used" with the spacebar (Option)
Falloff profiles on gradients, transparencies and feathering.
Boolean operations that works with bitmaps and vector objects, also on groups as whole
mouse operations:
Right-Click + Drag to copy
Ctrl-Click to select inside groups
Alt-Click to select under objects
Swatches: Left click = fill color, Right-Click = line color (Preference)
Nudge feature (arrows) with alt/shift/ctrl combinations modifiers to apply different increments sizes.
You can set a hotkey that sends a bitmap directly in a external editor (photoshop for example) that updates it when you return.
Marc
4277.40
Hello,
Did you recreate those vector gradiants in Xara from a MoI reference? They look great.
4277.41 In reply to 4277.40
Hi, those are raster screenshots straight from Moi under the vector lines!
I take them at Hi-res (removing the edges visibility) and crop a transparent background in photoshop
The lightning tweaks in Moi are often enough to get the effect I need.
Marc
4277.42 In reply to 4277.41
This is a long thread. I don't know if anyone has mentioned Swift3D. It's for 3D to Flash conversion but I has EPS/AI export too.
4277.43
Hello,
I tried Swift3D a while ago. It seems the output is not too exact and does segmenting on curves, although it looks pretty good if you want to do Flash animations.
4277.44 In reply to 4277.43
To translate subdivision models to vector curves is surprisingly hard to do.
I've spend some time searching for a software that would do this, but did'nt find anything either, all vector outputs are segmented polygons.
Maybe I haven't dig enough though, there must be something...
That's one of the reasons I like Nurbs so much!
I found two workaround solutions,
-Convert the Sudb model nurbs and extract curve data (with T-spline for example).
-Using a cel material, then trace the bitmap render output to vector (with vectormagic or something similar).
Marc
4277.45 In reply to 4277.44
Hi Marc, yeah it's pretty common for polygon sub-d modeling programs to kind of treat sub-d surfaces as just a way to take some polygons and generate more polygons, rather than actually focusing on dealing on the actual smooth "limit surface" itself...
4277.46
I've done a quick copy of your plug and a video of how to get better results with ViaCAD v7 for this task. It's not perfect, but it might help you along a bit if you can't find something better at a reasonable price.
I've attached an Illustrator and a DXF file of the plug for you to look at.
Martin.
http://screencast.com/t/VmxGbV6lVI
4277.47
To get this so called two-line-weight renderings I currently use Cinema4D and Sketch & Toon. To get the thick outline rendered properly all individual objects of the plug must be connected in C4D. I attached a sample rendering. If I somehow could download the plug model I could post this too.
Although C4D + S&T works very well I would prefer a direct workflow from MoI to Adobe Illustrator that would give me the same result without much work. Especially because the illustration would remain in vector format. It would help a lot if MoI (optionally) didn't export hidden lines to the .ai format.
EDITED: 2 Jun 2011 by MARTIN3D
Size: 97.5 KB, Downloaded: 81 times, Dimensions: 1082x397px
Show messages:  1-17  18-37  38-47
