Free Autodesk
 1-17  …  38-57  58-77  78-97  98-107
4247.78 In reply to 4247.74
Hi Paq,
I havnt used the OBJ import yet, but will load it and look too, to see if I notice anything.. But for sure, the app is sensative....
4247.79 In reply to 4247.77
Hi PaQ,
> Maybe it's a data precision problem, the log file report
> this : 'La conversion de la chaƮne "0.0173325" en type
> 'Single' n'est pas valide' (sorry for the french).
Probably not precision, but more likely an internationalization bug - you must have a locale set in Windows that uses the comma character as the decimal point separator?
That program is probably expecting then that numeric data should use a comma as the decimal separator, but that's not the case in OBJ files - OBJ use the period as the decimal separator for numeric values.
Try switching your Windows locale setting to English, or possibly just set the decimal separator setting to a period (as shown in this post here: http://moi3d.com/forum/index.php?webtag=MOI&msg=4282.5) and then maybe that other program will work.
If that does work, then that's a bug in that program, it's using a locale-specific number parsing method instead of using a method that will always use the period as the decimal separator.
> 123D didnt work for my son at all, the viewport manipulation
> is to weird for him. It was funny to see him bitching about all
> the popups too :)
I'm not too surprised, it's hardly different from their regular version which is targeted towards mechanical engineers basically...
I bet your son could learn it if he was introduced to it as part of a class instead of just trying to figure it out directly.
4247.80 In reply to 4247.79
Hi PAQ,
I just did a test with Hexagon and an OBJ import/conversion with the newer stl2step converter..
I revieved the error also from a default export from Hexagon.. I then did an export and deselected "Export UV's and Export Normals" and the import into stl2step succeeded!
I havnt tested to see if it was one or the other yet, and I dont know what you have in Modo upon export, but you may look at eliminating some of this information from the export to get the model in... :o
4247.81 In reply to 4247.80
Hi PAQ,
It was the "export normals" option.. Without that, the conversion succeeds. My simple test file has 5888 faces in the STEP file and comes in as a solid.
4247.82 In reply to 4247.81
Hi guys,
I give Michael suggestion a try, I was able to go a step further, but now the error is : The index is outside the array bounds (personnal english translation).
I've removed the uv's (didnt help), but I cant discard normal info when doing the export in modo.
I'll give a try with 3dsmax Tuesday at the office.
Thanks for your help.
4247.83 In reply to 4247.82
Hi PAQ,
Here's the OBJ I tested with that had the normals option unchecked in the export.
Also, Michael had mentioned the Integritywares application. You said you have Max and they have a plugin that I believe only costs roughly $200.00
I think it actually makes smooth NURBS surfaces as a result. I have been excited about seeing this crop out in something that we could utilize.. Just hoping at this point. I contacted them about a standalone option, but I dont think they were interested..
4247.84
I spent several days to test 123D, and in my opinion, it can become a very good companion of MOI.
The good of 123D :
In fact, 123D uses the same engine as Inventor/Fusion, a robust CAD application with an history tree. This means that when you create a feature like a bevel, you can later edit this feature, and the object is remade to reflect the modifications. Moi, on the other hand, doesn't have this tree.
Another very interesting feature of 123D is the ability to push or pull faces of a finished model, a thing that you can't do easily in MOI, even with the "point edition". In the same way, you can at any time rotate faces in 123D.
The bad of 123D :
As a lot of CAD engines, to create a curve, you have first to create a plane, then create your 2D curve on this plane. And 123D doesn't allow you to modifiy these curves in 3D as MOI.
The process to create features as a loft in 123D become very difficult : you have to create numerous planes, then your curves, and so on.
In MOI, on the contrary, the process is efficient, simple, clear, and much more powerful than the one in 123D.
So ? You can obtain best of both worlds : first I create my object in MOI ( without features like bevels that can produce bad models at export ), and then, I can edit them further in 123D, by moving faces (even curved ones) and rotate them as well. In two words, 123D adds a bit of "interactivity" in the process of making an object.
I'm not a fan of Autodesk. In fact, I think it's one of the worst 3D company in the world. But with 123D, they released a powerful and free tool. Even bad companies can do good things sometimes. :)
On the other hand, to say the truth, I'm a big, big fan of MOI, I think this software is a kind of "miracle" in the jungle of heavy, expensive NURBS softwares.
It's clear that 123D isn't able at this time to replace MOI; it can't beat the power and efficiency of MOI, and it is very far from it. But 123D can add some useful functions MOI doesn't have... at this time.
Worth the try in my opinion. :)
Alexis - www.3dsaloon.fr
4247.85 In reply to 4247.84
Hi Alexis, yup that is a good way to look at it.
In MoI the focus is on making it easy to draw something from scratch, and not so focused on adjusting an already created model.
123D is sort of the inverse - it's more clumsy to draw in it, but very convenient to make adjustments to existing models in it (or it would be if they can improve the performance).
So together they could be a good combination!
One thing also to keep in mind is that 123D is focused on generating output for 3D printing and not on making output for rendering programs (like writing OBJ or LWO files for example).
4247.86
i just tried 123d for 4 days, i don't like it.
4247.87 In reply to 4247.16
there is nothing free from autodesk.
that is probably another bloated commercial bag.
just like many products on the market...very few technical innovations and loads of commercial ones
that you never use, but average customer gets the impression that they are getting loads for very little money.
be aware of free offers. we should make great effort in educating people about classical geometry so they can understand
that purchasing load of colourfull buttons is not necessarily what they need. autodesk is after different kind of education!
anyway...this forum is for hard core modellers.
4247.88
The main problem with this new app, besides the usability issues Michael has mentioned, is the use of "sketches" instead of individual curves, which do not have grouping(and group operations) forced upon them; this and, as already mentioned, 3d curves.
"Spaceclaim", what I use as a companion to MOI(its possible to copy and paste surfaces and curves directly from MOI - SC has native 3DM export), is similar, but does it the right way:
EDITED: 1 Jun 2011 by AMBIMIND
4247.89 In reply to 4247.88
Hi Ambimind, that was really cool when SpaceClaim added in copy/paste support for MoI.
I mentioned to them that it would not be difficult to add in since they already had 3DM support, and it was just a chunk of 3DM data on the clipboard, and they added support for it in the next version that was out just soon after that.
4247.90 In reply to 4247.88
And there are a couple of things that make that SpaceClaim edit boxes much less distracting - one big thing is having them positioned as more connected to some geometry in the model rather than trying to have stuff float around with the mouse.
Boxes that float around with every single twitch of the mouse just has such excessive motion.
4247.91 In reply to 4247.89
Cool, thank you, its very useful and efficient; the curves are not interpolated(as happens with AI export) and respect relative placement in each scene! - I only wish this was possible in the reverse. Actually, I had been wondering if you'd also advised them on their temporary-reference-geometry system - which is very powerful and similar to yours(perhaps it was diffusion-by-inspiration :) )?
4247.92 In reply to 4247.91
Hi Ambimind,
No, not by any direct contact, but it would not be surprising if they got some inspiration from MoI.
MoI's construction lines being based on 2 points (where you start the mouse drag and where you release it) also defines a distance to the cline which gives a lot more functionality than the more typical system that only radiates lines out from a single point.
4247.93 In reply to 4247.92
Yes indeed, after using them in MOI I unconsciously began drawing them in other apps - with no success :)
Spaceclaim's system works on selection of 1 or more entities, where the selection is not limited to one entity type - and produces reference points, lines, planes and curves; in 2d and 3d mode. Both systems have the big advantage that you don't need to manage these myriad entities. However Spaceclaim still lacks your innovative snapping system: I love how intelligent the inference system is, particularly in regard to mid points of lines, circles and quandrants that persist beyond the initial sketching phase(in any view) and that the various possibilities(eg. intersections,perpendicular connections, etc) have dynamic local representations in the form of suttle crosses.
There are a number of innovations of this type, the reference system included, which I think you deserve recognition for, in the form of patents - much as the early Alias|Wavefront marking menu system did.
EDITED: 28 Aug 2011 by PILOU
4247.95
If your using this stuff as a hobbyist and not for commercial work, you may as well sign up to Autodesk's educational program. Then you can get the full versions of all their software free. with no limitation apart from watermarks on Inventor and Revit's 2D technical drawing output (and a dire warning on start up about what will happen to you if you use the products for commercial work).
Fusion is included as part of the Inventor Pro package.
If you want to explore the ultimate in free form A-Class surface Nurbs modelling, try Alias Design. However the learning curve is almost vertical and the UI is worse than the original Blender. Trying Alias will probably convince you that MoI is better suited to what you want to do, unless you design car bodies for a living or need G3 continuity in everything. The Alias Design series is a good example of why Michael's approach to having simplified commands is important
However, for those looking for a free renderer for MoI, Max and Maya include Mental Ray and will import models from MoI.
EDITED: 28 Aug 2011 by STEVEH
EDITED: 25 Oct 2011 by PILOU
4247.97 In reply to 4247.96
Thanks Pilou...
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
Show messages:  1-17  18-37  38-57  58-77  78-97  98-107
