Thomas the train in 3D
All  1-2  3-19
4246.3 In reply to 4246.1
Hi Gaston, MoI is not really the best tool for making faces like that.
The primary workflow for MoI is to draw some profile curves and then build surfaces from them.
For mechanical shapes this works really well, because for many mechanical shapes the 2D profile blueprint curves define the overall shape.
That does not work so easily with a face because a face has such a constantly changing nature to it that just a single profile curve does not define the overall shape of the face very well. Like for example a side profile would include the nose but it is not correct for the nose to traverse the entire face side-to-side, it's a small localized detail. Faces are full of these kinds of small localized bumps and details.
Sculptris like Pilou mentions is a really good idea to try - it's easy to use and its method of sculpting by applying brush strokes allows adding little bumps and small localized details well. It's just a better tool for faces than MoI.
4246.4
Yes, but Thomas' face isn't really a face - it's two eyes, a nose (sorta) and a mouth.
http://4.bp.blogspot.com/_bz_jjvcbEUc/RtIgHtuZoXI/AAAAAAAAACc/5cy9pr9E9Yw/s320/thomas_tank_engine.jpg
I would say this could be done in NURBS without too many problems. Try a picture of the face from each perspective - maybe buy a Thomas toy and use this for your reference pictures?
4246.5 In reply to 4246.4
Hi Aaron, even though it's a simplified face, it's still got the overall issue of having very kind of "melted together" features within in it. Also because it's not too complex it means that you'd be able to do it really quite quickly in Sculptris - that tool is just a better fit for this particular kind of shape.
4246.6 In reply to 4246.2
Thanks Pilou,
I try downloading Sculptris but I keep getting the following message:
"This server can only be accessed by the proper referring server"
Anyone has an idea why I get that message?
Gaston
4246.7 In reply to 4246.6
Sounds like some kind of glitch in their web site.
You could try this other older location:
http://www.drpetter.se/project_sculpt.html
4246.8 In reply to 4246.7
Scultris and Dr Peter were grabbed up by Pixologic. The download page is here:
http://www.zbrushcentral.com/showthread.php?t=090617
At ZBrush Central.
4246.9 In reply to 4246.7
This link provides a previous release, Alpha 3 instead of Alpha 5 but at least I can download it.
It is when I try to download the last version available, Alpha 5, that I get the message "This server can only be accessed by the proper referring server"
Thanks Michael,
Gaston
4246.10 In reply to 4246.9
Alpha 5 is Pixologic:
Go to the page I listed and clcik the download link in the first post of the thread...
Clciking on the link (As if I linked to the zip file from THIS forum, produces that error.. You have to clcik the link from the zbrush central forum.
4246.11 In reply to 4246.10
This one here:
4246.12 In reply to 4246.11
Hi Burrman,
I followed this exact procedure and kept getting "This server can only be accessed by the proper referring server."
So I tried to download from a different computer and everything went as expected :?
Now I have two problem: learn Sculptris :o) and fix my computer :o( (I wish I knew where to start looking).
Thanks all,
Gaston
AH ok, for this sort of face you can use Moi, because it's a very stylized one!
4246.14
Here is a Spain video of someone who modells Thomas the Train with Blender. The last part 4 is three days ago, perhaps he will do in the next part the face.
http://www.youtube.com/watch?v=X8kP6B0Jwd8&feature=related
RUdl
4246.15 In reply to 4246.13
You must already have a tutorial ready on how to do this, do you ;o)?
If not, how would you go about it?
Gaston
4246.16 In reply to 4246.15
I will made it ;)
Here the concept ;)
Project the first drawing on a sphere then follow the mini tut
All flat a little at the end if wanted
(all is only moi except the black color on the eyes ;)
File 3dm : http://piloumaison.weebly.com/uploads/3/6/2/0/3620514/thomastrain.3dm
EDITED: 8 May 2011 by PILOU
4246.18 In reply to 4246.17
Wow Pilou,
you are good.
Denis
| Adobe Photoshop CS | Corel CorelDraw Grahics Suite X3 | Daz 3D Bryce 6.3, Carrara Pro 6.2, Hexagon 2.5 |
| Maxon Cinema 4D R8.2 | Moi 3D V2 |
4246.19 In reply to 4246.5
"Hi Aaron, even though it's a simplified face, it's still got the overall issue of having very kind of "melted together" features within in it. "
Fair enough. I haven't actually tried Sculptris.
Show messages: All  1-2  3-19
