trim/boolean/extrude command with curves
All  1-15  16-19
4228.16 In reply to 4228.15
< you don't have a simple only 4-sided rectangle
is that i had remarked my rectangle was multi segmented but thinking that had no incidence of its center!
<If that known position is not the position you want, then why do you care where it is?
it's alway good to know the middle of something ;)
< The center snap will not be very meaningful
I was affraid because i had made my array curve from the center and not from the end of the path so result was significant at the extremities for some function
Now I will take the end of path :)
Thx for the help and explanation!
Line both sides + array cuve line + Project lines are very funny for obtain numerous profils without effort from any volum!
4228.17
Talking about mixing commands, I think you could merge the plane and network commands to just one button, that new command could identify the result you expect based on the selection. Just a suggestion.
4228.18 In reply to 4228.17
Hi ed,
Possibly... But actually those 2 commands will currently produce slightly different output when given some of the same kinds of inputs. Like if you have a 4-sided boundary like this:
The Planar command will build a trimmed plane surface for that, while Network will make an untrimmed surface. You'll see the difference if you turn on surface control points for each of those results.
Also the Planar command actually does already have some multi use built into it currently - you can also use it to fill in planar openings on a surface object in addition to building a trimmed plane through a planar set of curves.
In the future I have to figure out where to put another kind of surfacing command called "N-sided patch", and I've been trying to think of how it might be combined with one of these as well.
But it can be a bit tricky to combine things when there are 2 different results possible from the same inputs...
4228.19
I understand, and i like the work youve done so far, then keep going!
Show messages: All  1-15  16-19
