C Plane
All  1  2-4
4219.2 In reply to 4219.1
Hi Rudl, sorry no there isn't anything like a saved cplane list in MoI right now.
You need to do something like create a plane in that spot so that you can snap on to it later on to get the same cplane back.
That is something that I want to add in the future though.
4219.3
Thank you,
meanwhile I think it is not important. I´ve found a good workaround.
A 3D plane has all properties to name a Cplane.
Rudl
4219.4 In reply to 4219.3
Hi Rudl, yeah since you can just draw directly on a plane surface object, those can often be used for the same kind of purpose.
Setting the cplane switches even more stuff to that plane, like typed in coordinates and also the Top/Front/Right views switch to be views of it. But if you just want to draw things with the mouse in the 3D view, doing that directly on a plane surface can work well.
Show messages: All  1  2-4
