Turn around selected
All  1  2-4
4218.2 In reply to 4218.1
Of course yes! :)
Click the Object
Click the Reset button (middle bottom view)
One click = Center the Object
Click and Move over the icone Rotate! (middle bottom view)
Another Click on the Reset button = center all the Objects
EDITED: 23 Apr 2011 by PILOU
4218.3 In reply to 4218.1
There is also a sort of "TurnTable" Command here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1001.1
4218.4 In reply to 4218.1
Hi Rudl, yup like Pilou says the Reset button is what you want to center the view on the selected object. That will both zoom that object to be framed on the screen and also set the rotation pivot point for the 3D view to be at the center of that object as well.
It's this button here:
If you want to focus in on one specific point of the object like a corner of a box or something like that instead of the whole box, then use the Area zoom tool that is on the left side of that same toolbar - in addition to zooming in on a particular area it will also set the rotation pivot point for the 3D view to be at the particular point that you picked as the center of the zoom rectangle.
There's some info on this in the documentation here:
http://moi3d.com/2.0/docs/moi_introduction.htm#view
Show messages: All  1  2-4
