sweep makes wavy ends
4212.1
Why does I have here wavy ends?
Rudl
Size: 125.6 KB, Downloaded: 140 times, Dimensions: 1440x900px
4212.2 In reply to 4212.1
Hi Rudl - it looks like on your sweep you had switched the "Twist" option to be "Twist = Flat".
Try switching it back to the default value of Twist = Freeform instead.
The "Twist = flat" option means that the profile will only pivot around one direction, but if you use this option you should not have your path going along the same direction as the pivot direction, because having both the path and the pivot in the same direction makes the rotation poorly defined and things will kind of shift suddenly in areas where the path tangent and pivot direction are the same.
But basically - don't use "Twist = flat" when you've got sweep path that is going in the same general direction as the flat pivot direction.
4212.3
Try redoing the sweep but this time use the long curve as the profile and the short curve as the path. Set the twist option to Freeform. It may be closer to what you want.
4212.4
Michael,
Do you ever stop? It must be 4 o'clock in the morning for you.
4212.5 In reply to 4212.4
Hi Steve, yeah it is getting about bedtime over here... :)
4212.6
Thank you both.
I did it now in the way, in which I will do it in reality. I did it with array along the height with count and angel.
RUdl
Size: 24.3 KB, Downloaded: 60 times, Dimensions: 493x600px
