fixing a solid
All  1-3  4-6
4197.4 In reply to 4197.1
Hi Jim, I've almost got it fixed up.
There are are few little inaccurate bits in this model that make it a lot more difficult to cleanup though, like for instance in this little tiny area here:
The cutting object did not go all the way through the other one, leaving some little teeny tiny shelf like fragments at the end of that cut:
Those kind of little tiny fragments and irregularities make it a lot more difficult to work on those areas.
4197.5 In reply to 4197.1
Hi Jim, I've attached a version that I think is all fixed up with that groove removed.
I did it using those techniques from that object repair tutorial - deleting the faces of the groove to start with, then separating out the other surrounding pieces into individual surfaces, untrimming those and then retrimming them.
The trickiest part is actually the retrimming, because when you do the untrim you get back the whole huge original surface, then you have to retrim that to the surrounding boundaries. To make good boundaries you also have to kind of start strategically at some of the bordering pieces and fix those up first before getting to the more central parts. It's kind of like fix up some of the edge pieces first to then get more restored edges to use for cutting the other parts.
Kind of complicated to explain unfortunately, there are a lot of little steps involved, the best attempt that I have at explaining it so far is that object repair tutorial above.
4197.6
Thanks Michael. appreciate that!!
Show messages: All  1-3  4-6
