IGS to LWO with MOI
All  1-11  12
4193.12 In reply to 4193.11
Hi Wedgie,
> Double clicking a mesh part, like the face plate, for
> example, wouldn't select the entire mesh as most
> of the meshes were not continuous.
Another way you can control this is to set the object names within MoI (click on the name line in the properties panel that shows up in the upper right area of the window when you select objects).
If you have multiple objects all with the same name, they will all be combined together into one mesh object in the LWO file if the setting for it is enabled - the setting is under Options > Import/Export > "Combine same named objects". It is enabled by default.
That gives you a way to control mesh clustering in the export as a separate thing from material assignment - the style assignments in MoI will become material assignments in the LWO file.
Show messages: All  1-11  12
