Middle curves
All  1-8  9-12
4180.9 In reply to 4180.8
Hi PlasmaFX - there is a plugin called LineWeb which can automate that process that you're doing there - you can get the plugin from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
Then for example on 2 curves like this:
Select those 2 curves and run LineWeb a first time to build connecting lines like this:
Then select those connecting lines and run LineWeb another time, and it will build curves between those lines in the other direction, like this:
Set the option for "Build: Curves" to build smooth curves going through the sampled points instead of lines.
That will actually do the same process as in your video (making some spaced points and then drawing curves through them), just automated.
4180.10 In reply to 4180.9
you can see my last video tuto about LineWeb
(it's in French but... :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=4119.20
EDITED: 11 Apr 2011 by PILOU
4180.11
Thanks to all for the solutions! The line web thing is a great way to do it!
4180.12 In reply to 4180.11
Cool plugin, so iit is maybe great for creating an icehockey vizor?!
Show messages: All  1-8  9-12
