Boolean problem
All  1-2  3-14
418.3 In reply to 418.2
Thanks for votre réponse, monsieur Pilou :-)
The files in attachment.
I tried with the yellow object higher of 0.01 units, and the boolean works.
But with this like in the files, it don't work.
ps : thanks for nice objects. I think your link in the thread gallery is not good ;-)
418.4 In reply to 418.3
Sure I have writed 2 for 1 :D C'est ok maintenant :)
For the problem
1 you have 2 boxes :) Click Move the box :there is another box inside! :)
But that was not the problem !
2 Move all the "boxes " out of the "object" Kill one of the "box"
Select only all the "pied a coulisse" : make boolean Union
Put the "box" at the good place
Make Bollean Diff
All works as a charm :)
EDITED: 19 Feb 2007 by PILOU
418.5 In reply to 418.4
Thanks Pilou.
Sorry for the two boxes (it's an error of me when i prepared the files, in the original, there aren't 2 boxes).
So I tried the union (why union because there is only one object ?) like you say, but this doesn't work too. Or I don't understand all of this.
I have only 2 objects in the new files in attachment ;-)
I would like make the boolean diff in the same objects position than in the files. Nothing occurs.
(in you file, the cube isn't in the same place than the original file)
EDITED: 28 Jul 2018 by FINEMA
You right ! Not exactly at the same place :( - too speedy)
So wait Michael answer, I believe that is something curious in the first object
Maybe this piece
I delete it and
Booleean Diff works with the rest (? )
Founded :)
418.9 In reply to 418.8
Thanks Pilou. I don't know how this is arrived.
And how can I resolve this ? All to start again this piece?
I can achieve the caliper with the yellow object higher of 0.01 units nevertheless :
http://jipsou.free.fr/moi/PiedCoulisse04aP.jpg
But I would like to understand how to resolve the first problem ;-)
418.10 In reply to 418.9
< All to start again this piece?
Normaly not :)
Some join, extend, extrude, loft, boolean must be suffisant
418.11 In reply to 418.10
Bonjour Buzhug, Pilou,
Yes, the problem is in the area that Pilou points out - there are some very skinny surfaces in this area, where a very small shelf on the side approaches the main part within 0.0002 units . This type of situation tends to confuse the boolean operations, at around this distance it is better if the shelf is either exactly flush with the object, or a larger distance away.
This area of the model is a little confusing to me in general, I can't quite tell if the little shelf sticking out is important to your model of it is more of an accidental thing left over from some other boolean operations.
In general it is not necessary to start over again, there are techniques that you can use to edit individual pieces of your model to fix them up.
To do this, you would select some of the faces that are messy, and then do edit/separate - this will detach those faces from the main object, at which point you can hide the main object to get it out of the way. Then you can select this sub-structure and do edit/separate on it again which will now break it up into individual surfaces.
But I'm not quite sure if that little shelf is important to you - if it is not, then you would want to delete those little slivery surfaces and reconstruct the side with more of a simple single planar piece or something.
Another tool for fixing up a shape is untrimming and retrimming - this can allow you to fix up a trim boundary that isn't quite right. Often times for this you might select the existing edges of the surface and duplicate them with copy/paste, then hide them. Then select all the edges of the surface and hit delete - this will remove the trim curves from the surface and recover just the underlying surface. Now you show the original trim curves, make any edits to them to fix them up, and then re-trim the surface with the edited curves.
After doing these tune-ups or reconstructions to individual pieces to fix things up and remove little messy areas, you can then use Edit/join to merge them back together into a solid.
I would do some of these steps on your model, but like I mentioned, I'm not quite sure what your intent is with that little shelf area that is sticking out.
418.12 In reply to 418.11
OK.
Thanks, Pilou and Michael.
Thanks a lot for your explanation, Michael.
You are right for the problem. The little shelf is an error, and not desired. I don't know how i arrived at this. An error from me, sure. Now I understand.
The result, with render with cinema4d :
http://jipsou.free.fr/frc4d/Objets/PiedACoulisse01-53P.jpg
So thanks a lot, and congratulations for your soft.
I continue my exploration.
418.13 In reply to 418.12
Great looking render, very realistic materials.
You abuse of the dof :D
Show messages: All  1-2  3-14
