How can I cut this tubes
All  1-3  4-6
4179.4 In reply to 4179.3
it's not A-B, it's the last boolean function "Merge" who trim all the objects between them
So you can kill anything that you don't want ;)
4179.5 In reply to 4179.3
Hi Rudl - just to help clarify, Pilou is talking about this button here:
The Boolean "Merge" command slices everything up and leaves all the pieces behind so you can then just delete the pieces you don't want.
It's useful for situations like you have here.
The other option for cases where you want only some portions of an object removed is to use the Trim command, but the boolean merge command is kind of easier if it works for what you need.
4179.6
Thank you all together.
Rudl
Show messages: All  1-3  4-6
