Parametrics
 1-9  10-21
417.10
Micheal are you aiming for total parametrisation or smething more like Rhinos history?
If the second one....maybe we could give you some tips or ideas...
EDITED: 19 Feb 2007 by KRETEN
417.11
[quote]The future of MCAD is Direct Modeling. History-free Modeling. Dynamic Modeling. Freeform Modeling. Anything-But-Parametric Modeling.[quote]
See here.... hehe..
Petr
ps: Rhino's History is very similar to MoI one. It is not parametric modeling or something like this.
417.12 In reply to 417.10
Hi Kreten, V1 is aimed at more like Rhino-type history common to several NURBS based applications. Actually MoI goes beyond Rhino a bit in this area since it applies history to more commands (sweep for example), and also updates history dynamically while editing instead of only when you finish a pick - for example, drag a control point in MoI and you see the history update while you are dragging instead of only after you finish dragging. This combined with MoI's very fast meshing allows for history to be applied with shaded feedback very well.
Let me know if you feel that there is something missing in MoI's history compared to Rhino.
In future versions I expect to extend history to apply to more situations.
417.13
Micheal heres a little something, an idea, thats not related to history at all, but maybe has an feel to it.
Also not in Rhinos power but in power in some other NURBS apps. like AmapiPro...
o.k. here goes
1. I fillet the upper edges of the cube
2. later on I realize that I have forgoten to maybe fillet one "side" edge. If I try to filet it, I get the "sharp" edge where the 3 fillets met. And thats bad! :-(
3. I want to get smooth transitions in the place where the 3 fillets met, like in the pic.3.
You could maybe make it possible then to choose what kind of meting place you want to get, smooth or sharp...
417.14
p.s. also maybe an an idea to get this kind of a "edgepoint" fillets....people modeling bolets parts would spare a lot of time here!
417.15 In reply to 417.9
Hi JTB,
> Michael, since parametrics, connecting and grouping objects are relevant, have you
> thought about all those methods mentioned in the other thread?
> http://moi3d.com/forum/index.php?webtag=MOI&msg=384.1
> Any (even temporary) decisions?
No real decisions yet.... I haven't really had any time yet to focus on this area. It's probably going to take some sketching and prototypes before I'll be able to figure it out. It's pretty time consuming so I haven't had a chance to dig into it yet.
417.16
Michael any luck with the filleting issue I talked about in the previous post?
417.17 In reply to 417.16
Hi Kreten, those ones are not going to be as easy to add immediately, they involve a lot more changes to workflow and program UI.
Those ones will have to go on the wish list for a future version.
But the blend-style fillet is looking pretty good.
417.18
o.k. Maybe for V2 then...but the blend thing is unbelivable! :-)
417.19
I have to agree with Petr. Parametric modeling has it's place, but I don't think it is here. The free form styling tools currently provided in MoI are excellant! I deal with the problems of parametric systems all day long. I'm not knocking them, but I think the two should work together (i.e. via import/export) but be kept seperate.
Michael T.
Michael Tuttle a.k.a. mictu www.coroflot.com/fish317537
417.20 In reply to 417.19
Hi Michael T -
I guess it is easy to get tripped up on terminology here. When I say that in the future MoI will have additional parametric functionality added, I mean it in a pretty general sense. That is that it should be possible to modify some values (for example the radius of a fillet), and then basically have that command automatically run again to generate an updated model.
This will be an optional thing that will show up in some kind of object history browser.
It won't fundamentally change the workflow of how you draw things in MoI - like for example it doesn't mean that MoI will force you to define sketch planes, etc... MoI will remain a sort of loose and free drawing environment as it currently is.
If you don't go to the history browser to change anything, you won't notice any differences from the current appoach. Well, except your files may be bigger due to additional data being stored, but I'll be sure to have a way to turn that off as well.
That's the idea anyway. So it won't really bring about any major workflow restructuring in MoI, if that is what you are worried about.
It also won't have all the exact same functionality as a "parametric solid modeler", but it will let you alter "parameters"...
Anyway, I'm not sure when this will be available, it might be a while.
417.21
Thank you Michael G. for clarifying that.
Show messages:  1-9  10-21
