Upgrading parts
All  1  2
4141.2 In reply to 4141.1
Hi Mark - sorry no MoI does not have any functions in it for having a model contain parts that maintain links to external files and automatically update like that when the external file is edited.
You'll need to use some other CAD software for that kind of task - you might try one of the "all the bells and whistles" parametric solid modeling programs like SolidWorks or SolidEdge - those systems usually have a lot of functionality around managing assemblies of parts.
MoI on the other hand is much more focused on just drawing shapes and not on that type of management.
I would like to look at adding external reference functionality into MoI in the future, but it's hard to say when it will happen - such functions often require a lot of UI within the program to work with them and a big focus for MoI is to have it streamlined and easy to use and focused on drawing things, and some kinds of things do not tend to go along with that focus so much...
One thing that you can do with MoI is to put frequently used parts into a separate file and then you can use MoI's "ImportPart" command to open that file and then it will also allow you to position the imported object right then as well. The ImportPart command is available by right-clicking on the File > Import button. But the imported geometry just becomes part of your current model, there is no update linkage for propagating changes.
Show messages: All  1  2
