Thanks very much for that, did a quick test & works perfectly.
Just what I was after.
At present I rarely have to use the "Vertical" option, but I'll keep that in mind should the need arise.
Also FWIW...
Thought I'd better double check to see how the script "RingCircle" produced it's Circle curve seam.
It's seam is also produced at the side, as in the Default Circle curves position.
So I'm wondering what section of the new Circle script would I need to copy & paste part into the existing RingCircle script?
Or is this something that'd be better off leaving for you to do??
Hi Colin, for RingCircle it involves modifying the lines where the X axis and Y axis are set - I've attached a modified version of RingCircle that has that modification in it so it will put the seam in the south location as well.
This is using the version of RingCircle that you posted a while ago where it has the British sizes at the top.
