Hi Ditto, there are a couple of plug-ins that you can add in to get some construction lines that last for longer than the current command, check them out here: http://kyticka.webzdarma.cz/3d/moi/#KeepCLine
If you set up the script there labeled "Keep construction line", on a shortcut key, that will then cause any construction lines created inside of the current command to stick around after the command is ended instead of going away automatically like they normally do.
It would be nice in the future to add in some more methods for manipulating construction lines, but it can be hard to figure out a good UI for managing them that is not too obtrusive.
Hi Michael, thanks for the pointers. These look actually to be what I was looking for. Great stuff. And I should have known that there is a way in MoI: This software is just brilliant (a small reflection of it's inventor, certainly ;)
And make lines or curves in a special color say "pinky" don't make the same work like construction 's lines?
You can use them like a special grid of construction, no ?
And hide them as you want ;)
You could also use your regular lines as you were, name them something like 'construct' and lock them, in that way object snap still works with them without worrying about moving or deleting them accidentally.
