Feature suggestions
 1-15  …  56-75  76-95  96-115  116-135  136-155  …  196-214
412.96 In reply to 412.95
Hi Pilou, one way to fill a hole is to remove surface trims.
Here are some steps on how to do that - this shows the steps for removing a hole in a cube:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
Here is a longer tutorial about removing holes on a more complex object:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
There will probably be another "fill in hole" tool at some point called N-Sided Patch. I might be able to do this one soon, I'm not quite sure yet.
Moving a hole can be pretty difficult, especially if there is stuff attached to it. It will be quite a while before I'll be able to work on this one, although probably this will get better with more history support, if you could control the history of how the hole was originally created. There should be more stuff for that in V2.
412.97 In reply to 412.96
Sure.... I had thinking an automatic filling hole :)
Symmetry by 3 points
412.99
beautifull soft, for me, a dwg or dxf import (2d at least) would be a great enhancement...
great job!
412.100
Would it be possible to have a Bend along curve option. It would go well with your new boolean curves to form shoe treads, tires and stuff like that.
412.101 In reply to 412.98
Hi Pilou, I've got this one on my list (defining mirror plane by 3 points), but I don't think I'm going to be able to get to it for V1. I should be able to get it for V2 though.
412.102 In reply to 412.99
Hi tmaes, thanks I'm glad you like it! I would like to add DXF/DWG support in the future, but it will take kind of a chunk of work to do it so I have had to postpone it from the 1.0 version.
412.103 In reply to 412.100
Hi Grendel - it is unfortunately quite difficult to do this properly.
For regular transforms like move/rotate/scale/mirror, transforming the control points of a NURBS surface is the same thing as transforming the definition of the surface itself perfectly.
I mean if you have a NURBS sphere and you scale the control points it has the exact same effect as scaling the "ideal" sphere.
But bending is not like this - if you bend the control points of a NURBS surface along an arc shape, the actual surface geometry is not bent precisely at the same arc shape. It will kind of follow the general bend, but it won't be exact - this is a problem because in an assembly where there are a bunch of different surfaces that are trimmed and joined together, if some of them are not precisely transformed in relation to each other, it will cause gaps to open up in places where there are supposed to be shared edges.
So that's why there tends to not be a lot of "bendability" of NURBS solids. Things that do support it (like the new stuff in Rhino V4) do a lot of work to "refit" the surfaces by adding extra points until they conform to the transformation with enough accuracy.
412.104
How do you feel about "drill-in" mode for composite curves?
Sometimes I want to handle (e.g. delete or mirror it) curve which is a part of (joined) curve; in this case I have to separate curve first, handle desired part and re-joined the rest. It would be simpler If I could select a segment of curve by clicking on desired part of previously selected curve.
Petr
EDITED: 2 Apr 2007 by TYGLIK
412.105 In reply to 412.104
Hi Petr, I would like to do something for this eventually. But when I was looking at it originally, it involved enough work that I decided to postpone it a while.
It's more than just selection work, for example you mention delete - to make delete work in this way would require modifications to delete. Similarly many commands might need to be tweaked to deal with this kind of input (curve segment selected instead of full curve selected). So that adds up to a fair amount of work which made it a good candidate to postpone from the V1 release.
There are a couple of other complications too - one thing is that it is a bit hard to think of a good way to represent this drill-in graphically. I mean what should I do to make it look like the segment is going to become the only selection with an additional click? I guess put a dark halo around all the other segments? This would have a pretty large visual impact on the way that curve selection works now. And it would mean that curve deselection would take 2 clicks instead of the 1 click to deselect as currently.
So one thing I've thought about is to not have a drill-in method for segment selection and instead have that as one of the available filter modes when selection filters are available. The way that would work is you would have the curve unselected, then set the filter mode to segment. Now when you picked on the curve it would only pick segments of the curve instead of the full curve. I was thinking this might be less generally disruptive. But then you have to remember to switch the filter mode back to "auto" or whatever when you are finished.
What do you think?
412.106 In reply to 412.70
[I wrote]
>>> Could it be possible to leave object(s) selected after joining or separating
>>> them using Join/Separate command?
[you wrote]
>This should be pretty easy to do, I guess I had better make the objects flash so that there is >a visual cue that something happened to them.
Hello, what's this then? :) I am so sorry about it. I should have been a bit more wordy when I had asked for your opinion concerning state of object after using Join/Separate commands.
It's okay with joining. The stuff flash and keep selected. Unfortunately, when separating a face/faces I would expect that only separated object/objects keep selected instead of all part of original object. It means that current behaviour is alright when exploding a whole object otherwise not.
Maybe other guys should give their opinion, since I am too hooked on Rhino's environment...
Petr
412.107 In reply to 412.105
>>What do you think?
I admit "drill-in" method for curves is somewhat less useful than for (poly)surfaces, but still useful. So solution using filter mode, you was thinking of, would match my needs. Of course, I can do without it for V1... hehe..
Petr
412.108 In reply to 412.106
Hi Petr,
Yes, that makes sense, I forgot about that scenario when I tweaked it.
This should not be hard to fix up.
412.109
Hello Michael, Hello All,
Let me start by saying that I like MOI very much. I do like to make abstract surfaces and objects for rendering. What I do need for that are the essentials options: bend and twist ( as seen in many modelling applications). Would it be possible to add this to V1? If V1 would include a good manual (currently I'm spending too much time trying to find out what things are doing) and the options bend and twist: you could absolutely count me as a new customer!
Best regards.
Hans
412.110 In reply to 412.109
Hi Hans,
No unfortunately I don't expect to be able to add these for version 1.0. It will actually be quite a while before these will be possible.
Probably the other modeling applications that you are referring to use polygon mesh surfaces. Those are a lot easier to twist and bend. MoI does not use polygon mesh surfaces, instead it uses NURBS surfaces. It is a lot more difficult to calculate twists and bends on NURBS surfaces, although NURBS surfaces do have advantages in other areas such as Boolean operations.
Here are a couple other recent posts that describe the problem in some more detail:
http://moi3d.com/forum/index.php?webtag=MOI&msg=523.13
http://moi3d.com/forum/index.php?webtag=MOI&msg=412.103
There will be a manual though.
412.111 In reply to 412.75
Bitmap tracing, Inkscape uses an existing library for this that works quite well.
PO Trace, http://potrace.sourceforge.net/
Works very in inkscape. Tracing a simple bitmap with Moi would be killer. :)
412.112 In reply to 412.111
Looks cool! Unfortunately I can't use the library directly because it uses the GPL license, which means it is only allowed to be directly included in other open source programs.
412.113
I'd like to have something like a button i can push to bring up a small window where i see all the objects and curves in my scene and then i can select the objects/curves i want from there and also reverse my selection. This is useful when you have large complex objects and selecting them only based on what you see in the viewport isn't always easy, it's kinda difficult.
Also i'd like to be able to export a selected object from a large assembly if possible, i can't remember if this can be done already so that's why i write here now. If this can be done already then ignore this request.
Many thanks in advance
/ Magnus
412.114 In reply to 412.113
Hi Magnus,
Yeah, this kind of object manager / object browser is probably the biggest missing thing in MoI right now. But it is going to take quite a bit of work to add a really good one, so this is something that I have planned to work on for version 2.0 of MoI, I won't be able to get this into the 1.0 version. But it is pretty much up at the top of the list for working on after version 1.0 is out.
This one is possible using File / Export. Export really means "Export selected". But right now it will only export complete objects that are selected, it won't do a sub-selection currently. So if you want to export just a few faces from a solid for example, you will need to use Edit/Separate on them to break them into separate full objects, then you can export those full objects.
412.115 In reply to 412.114
Dear Michael,
A stupid question for a super beginner like me.
Will V1 have a measurement tool,
where I can get the distance in between two points, example?
Thank you,
Rudy
Show messages:  1-15  …  36-55  56-75  76-95  96-115  116-135  136-155  156-175  …  196-214
