Tut Video
 1  2-21  22-41  42-51
4119.22 In reply to 4119.20
I love these images.
Are they rendered Frenchy or are they screen caps from MoI?
Mark
http://www.homepages.ihug.com.au/~mabrown/index.html
4119.23 In reply to 4119.22
It's just screen grab of the Moi Screen, then replicate an scale Size 50% on 4 levels in any 2D prog :)
Colors are Moi Colors but ajusting, reverse, etc in the 2D prog... depending of the feeling of the day :)
I have just 5 minutes free for make all the works! ;)
http://moizezennurbsmodeler.carbonmade.com/ ;)
A cool Portfolio maker http://carbonmade.com
An gorgeus gallery of artists all domains! (36 pages)
http://carbonmade.com/examples
EDITED: 15 Apr 2011 by PILOU
a little tut video ;) (Sweep 2 Rails, Explode Move, RotateObjects )
http://moiscript.weebly.com/pivoter-des-objets.html sorry always in French but visual :)
4119.29 In reply to 4119.21
This method of using booleans is completely new for me; how cooool!
I'd love to know by what principle its possible to predict the final shape?
Frenchy, I think you must be a radio presenter in France? - even though I can only make out the words "inspiration" and "solid", its entertaining to listen to your voice and its constant-variable-intonation :)
EDITED: 30 Jun 2011 by AMBIMIND
4119.30 In reply to 4119.29
Hi Ambimind,
Well, for that kind of operation the shape is generated by the extrusions of each profile curve and then calculating the boolean intersection between those extrusions. Boolean intersection keeps only the area that is inside of each extruded volume.
So to get a better idea of how it works you can do the extrusion yourself with the Extrude command to see what kind of shapes are being used.
Some other examples of this method in this thread:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3174.4
4119.31 In reply to 4119.28
Hi Frenchy,
I just watched your latest video and noticed that you have the ExplodeMove command left in English.. I didnt know if you were aware that you can rename those commands as well, so you could give the scripts and custom commands french names too... So if you take the 2 ExplodeMove files and rename them seevuplei, then you can type that to launch the command... May help your french speaking followers to do this to remmember a command..
FYI
4119.32 In reply to 4119.30
Thanks Michael, the intersection of 2 circle curves did not produce the shape I expected(and so my question) - now its clear.
@ Ambimind
< I think you must be a radio presenter in France?
You are so kind :)
@ Bur : I am too lazzy for make that and as the v3 is near to be releasead ;)
@ Michael
About the Boolean Diff / Merge
I have made that because if not I was obliged to kill one by one the internal result of a bolleean Merge multiple trimed !
Maybe there was an another way ?
4119.35 In reply to 4119.34
Well, if that was the result you wanted, Boolean Intersection is the most convenient way since it will automatically discard any pieces that were not within all volumes.
If you wanted to keep all the cut up pieces and use some of them instead of having them discarded, then that's when Boolean Merge can be good.
New V3 function Deform :)
Video : http://moiscript.weebly.com/enrobage-dobjet-v3.html
4119.37 In reply to 4119.36
Très bon, Pilou!
I can't wait to someday try the Flow command!
4119.38 In reply to 4119.37
Excellent Pilou,
I would even say awsome, I learn something about history, I understand it the wrong way around. I thought history needed to be setup on the original object, so I thought it didn't work yet.
I think I'll try also to setup up history on all object to see if we can tweek the original object, base surface or line and the target surface or line as well.
Felix
Function Twist (sorry in French :)
http://moiscript.weebly.com/twist-v3.html
EDITED: 19 Oct 2011 by PILOU
4119.40 In reply to 4119.39
Merci pour le tutoriel, Pilou! :-)
4119.41 In reply to 4119.40
Thanks Pilou. Although I don't speak French, the vids are good to follow.
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
Show messages:  1  2-21  22-41  42-51
