Sweep Questions
 1-5  6-21
408.6 In reply to 408.5
There is a bad sweep and a good sweep :)
But I am not sure that the result of the circular array will be the good piece?
Transition between the arc to the side of polygon will be the same following bad sweep (if surfaces are not cracked) or good sweep?
EDITED: 15 Feb 2007 by PILOU
408.7 In reply to 408.6
Hi Pilou - yup, you don't want to use the segmented sides as the rails, because then you're just back to the segmented-rail problem again.
> following bad(if surfaces are not craked) or good sweep?
Yes, the shape along all the edges should be the same in each case - but the internal parts are different.
Even later on when I can make the segmented sweep better, it probably won't be as good as the "good" sweep in this case though - there's sort of an issue of what to do with the profile in the transition between the segments - should it be extended and intersected? Maybe an averagead rotation between the 2 different directions? The abrupt shift of direction in the rails makes it hard to do something good there for all cases.
408.8 In reply to 408.7
So curves seems better and sweet than broken lines :)
408.9 In reply to 408.8
Sweep also accepts a stop and start profile, and 1 or 2 rails. So you can force how the surface starts and terminates. By judicious use, you can use then to sweep a segmented curve.
408.10 In reply to 408.9
Tricky indeed!
408.11 In reply to 408.7
Thanks for the clarifications
I was trying to get the hang of the sweep function - thats what the examples were, a way to try and teach myself
I think in Amapi so was confusing my self, once you get gorden surface that'll be huge to ;-)
thankyou M
and all for your quick responces
408.12 In reply to 408.11
hmm still having problems with more then one profile for sweeps
see example of hull/fuselage type shape
just cant do two profiles
408.13 In reply to 408.12
Hi Corzair, it looks like a bug for this particular situation where you have the rails touching at a point and the rails also stick out past the shape on the other end.
I should be able to fix this up, but in the meantime if you add an additional profile snapped on to the ends of the rails it should then work.
408.14
I'm struggling to get my finger out. (see attachment)
It's made of two rails and a two profiles. It fails to sweep.
I've just come to assume that if something fails then it's probably because I'm asking too much of MoI, and not that it's a bug.
408.15 In reply to 408.14
Hi Wibble - looks to me like a bug, can you please post the model file?
Looks like it may be related to the bug from earlier in this thread.
408.16
Okay, you asked for it. I'm going to give you the finger.
Still, I suppose it could've been worse; I could've been trying to sweep my willy. :O
408.17 In reply to 408.16
LOL I guess I prefer the finger! :)
408.18
I see the sweep will work if using either one of the profiles, but not using both...
jonah
408.19 In reply to 408.18
Yeah, the bug is that sweeps with more than one profile don't work, if the rails are sticking out past the profile instead of ending directly at the profile. Almost got a fix...
408.20 In reply to 408.19
Ok, both of these (Corzair's hull sweep and Wibble's finger) are fixed for the next beta release.
The bug involved multiple profiles when the rails were sticking out past the profile instead of ending directly at the profile.
Corzair, this bug is probably why you were running into general problems trying to sweep with more than one profile before.
Thanks both of you for posting the sample files, those make it a lot easier to track down what is happening.
408.21 In reply to 408.20
This is great, thanks Micheal
the sweep is really good now for making some great hull type forms excellent ;-)
Show messages:  1-5  6-21
