eps export
All  1-4  5-8
4065.5 In reply to 4065.2
Hi Michael, sorry but I don't understand:
>But it can export 2D curves to .ai format though...
I don't see it in the export tool.
Why I haven't the .ai format?
Is there something that I don't know?
Thank you for your help.
It's not a pressing thing.
FiL
_________________________
That's a brilliant day to design!
4065.6 In reply to 4065.5
Hi FiL,
Ah, but it is there.... ;)
Notice in your screenshot, there is a scroll bar on the right side of the list, here:
If you scroll down (click here):
Then you'll find Illustrator .ai as the last item in the list.
Also you don't actually need to use that list if you instead type in the .ai file extension in your file name. If you type in a particular file extension, MoI will write to that file type and you can skip setting that dropdown in that case. You only have to use the dropdown if you don't type in any file extension.
4065.7 In reply to 4065.6
I'm so stupid! I didn't saw it.
The basic use of pc!!!!!!
Nothing more!
Thank you.
Fil
4065.8 In reply to 4065.4
Thanks a lot Michael. It's working great with Mayura, the exported .eps file is scalled 1:1, so is great to use with older laser CNC machines for example.
Show messages: All  1-4  5-8
