MoI's ini format
All  1-2  3-5
4062.3 In reply to 4062.2
Hi Michael, yeah, difinatly ini is human readable, and as you have users and settings in there it wouldnt be something to do, yet.. But in the future, if you are working on the UI customization stuff, and perhaps create some sort of editor for the settings (Making Brian very happy, RIP) then there could be a switch made.
""""""""Is there anything in particular that you're looking to gain by having the settings stored in XML rather than in .ini format?"""""
At this point, it's just having access to it for my development purposes...(Spoiled with newer tools that can automate xml better than me writing line parsing stuff) As it is now, I am converting it to xml to work with and test.
For future use, the possibilities are much greater for development, being able to tie into other types of services...
At this point, without the third party support (And more my limited knowledge of the current programming requirments) I am pursuing different methods for plugin access and development.
4062.4 In reply to 4062.3
Hi Burr, there are Windows API calls you can use for reading stuff from .ini files, see GetPrivateProfileString:
http://msdn.microsoft.com/en-us/library/ms724353(VS.85).aspx
But yeah for customizable UI stuff that would more likely be in an XML file. Actually the layout of the main window is already stored in an XML file.
4062.5 In reply to 4062.1
Burr,
As a rule, unless there's a true burning need to have data that is hierarchical (i.e. some sort of parent child relationship), then xml is almost always overkill. Ini files are dead simple to parse, there are dozens of readers for them (in terms of code libraries) in most of the major programming languages, and they are easy to read and edit by hand. XML pretty much fails at all of those things. Since ini is just a text file it's also portable to pretty much anywhere.
Show messages: All  1-2  3-5
