Create Special Spring
All  1-2  3
4036.3 In reply to 4036.2
Hi guys,
One trick I use to do this is after generating a regular spring using a helix and sweep is to hide the spring solid, then turn on the control points of the helix, select a group, then using the rotate handle bar I change the center of rotation to where I want it, then rotate those control points until I achieve the desired effect. See JPEG.
Michael T.
Show messages: All  1-2  3
